Old 10-08-2002, 07:33 PM   #1
72futuresweet2wd
The face of my 69 c10
72futuresweet2wd's Avatar
Gas Tank Pressure
Does anyone else have this problem my Gas tank pressure builds up so much it forces fuel out of the key hole of the gas cap. It is doing terrible things to my paint. The original gas cap doesn't have a key hole but the fuel still dumps around the seal. Any help or advice would be appreciated.
2002 Harley Davidson VRod
1972 2wd Blazer (Project)
1969 Chevy C10 (Driver)
2002 Chevy Trailblazer (Wifes)
72futuresweet2wd is offline   Reply With Quote
Old 10-08-2002, 10:14 PM   #2
6869704X4
How are the 72s vented? Did they have the canister?
The more I learn about women, the more I love my truck.
6869704X4 is offline   Reply With Quote
Old 10-08-2002, 10:23 PM   #3
ThreeQuarter
ThreeQuarter's Avatar
The '72s had a vent tube coming form the top RH corner, and the hose ran up the RH cab corner over a hook and back down the cab corner wall and through the cab floor. It ran up the frame and across the rad. support to the charcoal canister mounted on the LH backside side of the rad. support.
Ben
'68 Chevy C10 Custom LWB 327/TH400 2nd owner
'16 GMC Sierra 1500 SLE Dblcab 4wd 5.3
ThreeQuarter is offline   Reply With Quote
Old 10-09-2002, 12:44 AM   #4
6869704X4
Maybe the vents clogged?
Old 10-09-2002, 10:46 AM   #5
72futuresweet2wd
This is on my 69 were they the same? I will check the vent tube and see if it is clogged this evening when I get home.
Old 10-09-2002, 11:06 AM   #6
ThreeQuarter
The EEC vent system I described is only on '72s. Which may be why you're having a problem with your '69.
Ben
Old 10-13-2002, 01:37 PM   #7
hanssolo
hanssolo's Avatar
Drill a small hole in the cap. 1/16". You won't destroy the planet.
69 C10 longbed: 357c.i. /TH400/3.73s/AC/ beige primer/saving $ for paint
______________________________
hanssolo is offline   Reply With Quote
