Old 11-15-2007, 05:58 PM   #1
burnitdown612
auto locking hubs
My auto locking have been skipping when i go down the road in two weel drive they try to engage and make some baddd noises ... it started eversince the last time i had it in 4 weel low ... Even before this they wey were having trouble engaging and when they did they would smash in ... my truck is a halph ton 87 with 6 lug axles .. anyone with anyideas as to what could be the problem. Also i would like to know how to swap them to manual ... i got the cover off and the main bearing is out i just cant figure out the rest.
1987 k10 silverado 305/700r4
burnitdown612 is offline   Reply With Quote
Old 11-15-2007, 07:18 PM   #2
duallyjams
duallyjams's Avatar
Re: auto locking hubs
Throw those auto hubs away and install manual hubs.
James
63 GMC V6 4speed carryall
65 chevy swb bbw V8 auto
68 K20 327/4 speed, buddy buckets
2002 GMC CC Dually Duramax
64 GMC lwb 3/4 V6 4speed SOLD
66 GMC swb bbw buddy buckets SOLD
IG duallyjams
The only thing that stays the same is constant change!
duallyjams is offline   Reply With Quote
Old 11-15-2007, 11:57 PM   #3
If you buy manual hubs it`s a remove old and install new operation.Auto hubs were prone to failure(if they got used).Warn made auto-locking hubs years ago.But,they could be locked-in manually.They recommended locking them in for compression braking and loads.They should have said for off road use also.I tore those up.I locked the new ones in for everything but a quick use of 4wd,lke backing out a stone drive or a slick spot in the road.Nothing beats the ol' "get out and lock`em" routine.
