engine decode help
on the front of the engine the number is
v1010zdd can someone help decode it. below the number is ejk but the J could be a U or ? The heads are 462624. I wanted to find out if there is anything special about the heads. I know there not hump heads, but are they better than the average head...... and what size engine it is...year ect. Last edited by xshadow; 11-15-2007 at 10:57 PM. |
Re: engine decode help
Maybe an 1981 corvette engine??
Not sure if you have all the numbers you need, here's where allot of us get the correct info for blocks & heads.
http://www.mortec.com/ |
Retired Air Force Veteran
![]() Join Date: Aug 2007
Harry 69' SWB Step Side 1/2 Ton w/68' Front Clip Swap from Leafs to Trailing Arms (Complete) Swap 6 Lug to 5 Lug (w/ Disk Brakes in Front) 3/6 Drop ![]() Help Support The Board Click Here For Information On How To Subscribe Krue's FAQ Page Vendors |
I went to this site:
http://www.nastyz28.com/chevy-engine-code-stampings.php If i'm reading it right it looks like a 1981 engine V= flint 10=october 10= 10th day ZDD=1981 190 hp manual trans 4bbl vette????????????????????? There is a picture near the bottom that looks like where I got my number from. In the picture it has a number that starts with the V like mine.... What I'm confused about is On the back of the block on the drivers side there is a place that looks like a vin number stamped on it it would decode it as a 72 1/2 ton pickup balitmore IF it is really a vin number for our trucks stamped ino the back of the block. There is a smooth area kinda oval maybe 2" long with the cce142b....number stamped in it. Last edited by xshadow; 11-15-2007 at 07:40 PM. |
The heads look like 75-86 350/400 76cc chamber. Is a 76cc chamber good?
The dd on the block corresponds to a 1969 307 2bbl 200hp.
I see but what would the Z be for? and the heads are for a 75-86?
I was looking at decoding the entire thing... V.....Flint 10....october 10....10th day the rest is ZDD?? I see ZDD as 81 350 M/T 190 hp vette? That would go along with the heads being 1975-1986 I'm only going by what the website looks like so I'm not sure.. would there be any other place on the block that would tell me the date? So I can see if it's dated around 69 or 81? Over the years the heads could have been changed? Last edited by xshadow; 11-15-2007 at 11:47 PM. |
