Old 11-15-2007, 08:58 PM   #1
gottwake
gottwake's Avatar
WTB 71-72 Front suspension hub to hub + X-member In CA
I am looking for a complete 5 lug disc brake crossmember from '71-72 2wd pickup. Hub to hub with coils, upper and lower a-arms, calipers, spindles,etc... In california please
Blazer Project
gottwake is offline   Reply With Quote
Old 11-15-2007, 10:33 PM   #2
jerry moss
Born Psycho
jerry moss's Avatar
Lightbulb Re: WTB 71-72 Front suspension hub to hub + X-member In CA
Bill at vintage chevy truck in fremont, ca. (510) 651-5874 will have what you need if you can't find anything closer.
jerry moss
72 cheyenne super K20- tilt,tach,vacuum,speedwarning,buckets,shoulder belts,am/fm,tow hooks,bumper guards,toolbox,aux. fuel tank,posi front and rear,plus other goodies!!! SOLD
69 suburban K20-tilt,tach,vacuum,speedwarning,buckets,shoulder belts,am/fm,4 inch all spring lift,4 speed, 14 bolt full floater, dana 44 HD,warn winch,posi front and rear,tow hooks,plus other goodies.
73/80 chevy/gmc K20 SB400,turbo 400,205,tilt,a-c,gas hog.
77 K/5 cheyenne blazer-daily driver/beater. SON HAS IT NOW
BRENTWOOD,CALIFORNIA
jerry moss is offline   Reply With Quote
Old 11-15-2007, 10:42 PM   #3
gottwake
gottwake's Avatar
Jerry, Thanks a bunch.
Blazer Project
Old 11-16-2007, 12:43 AM   #4
hotrodhomi
hotrodhomi's Avatar
Do I smell a 2wd blazer conversion in the works!
'72 2wd blazer, bagged w/ watts link & EDC
'72 C10 "Lowered Farm Truck" STOLEN 5-18-11
'66 impala ht
hotrodhomi is offline   Reply With Quote
Old 11-16-2007, 02:13 AM   #5
t korinek
Truckin' Krazy
t korinek's Avatar
Got the complete setup in phx AZ $200 if you want to make the drive.
Dealer for:
American Auto Wire
Precision weatherstripping
Dakota Digital
Trim parts Carpets
Truck World seat covers
& Many others
Chevy Parts locator in Mesa AZ!
t korinek is offline   Reply With Quote
Old 11-16-2007, 09:14 AM   #6
gottwake
gottwake's Avatar
Man...just moved from there. Do you have a photo?
Blazer Project
Old 11-16-2007, 09:18 AM   #7
jorgensensc
jorgensensc's Avatar
Just out of curiosity why couldn't you do a 73-87 conversion. The crossmember is dirt cheap and should be plentiful around your area. That way you could upgrade to the 1 1/4 heavy duty brakes. Parts are cheaper also. Just an idea.
Shawn
1972 C20 Suburban- Big Blue Betty
'56 Chevy Bel Air Sedan- Frame up Restoration
-What would you attempt to achieve if you knew you could not fail?-
-I Refuse To Tiptoe Through Life, Only To Arrive Safely At Death's Door-
R.I.P. EAST SIDE LOW LIFE
jorgensensc is offline   Reply With Quote
Old 11-17-2007, 02:19 PM   #8
gottwake
gottwake's Avatar
I think because the 72 bolts right up. Am i correct? Also, is the 73+ the same width as the 72-71?
Blazer Project
