11-15-2007, 11:52 PM | #1 |
Frame swap decrease value?
Did 68's have serial numbers stamped into the frame? If they did where is the number?
If I want to swap a frame, does it decrease the value of the truck if I am doing an original restoration. All other numbers will match, just the frame will be different. |
11-16-2007, 01:00 AM | #2 |
Re: Frame swap decrease value?
There is 2 places where the # are stamped. One is on the top of the frame rail under the cab and the other is is close to where the arrow is pointing.
72 Cheyenne Super 80 Silverado Blazer 2wd |
11-16-2007, 05:12 AM | #3 |
I have seen a few 67-68's that never had the one by the arrow.
68 Chevrolet k20 Longbed 350 SM465/205, Dana 44, 14bolt, Power steering, Power Disk Brakes, 35" BFGs. 84 Chevrolet Suburban K20 6.2 Banks turbo TH400/NP208 Now with G80 68 GMC C20 Parts? Truck And a few cars |
11-16-2007, 05:21 AM | #4 |
With a really nice resto I don't think that it would decrease the value that much.
WHat's the frame switch for anyways?
"Remember, They can Kill You, but they can't eat You, That's against the law!!!!!!!!!" |
11-16-2007, 08:33 AM | #5 |
Active Member
My 68 is stamped on the side of the frame under the drivers door or about there as my cab is off.
Jack
68 Chevy Long utility bed. Now swb/Bagged Soon to be 468 (Maybe 496) BB/Turbo 400 |
11-16-2007, 09:38 AM | #6 | |
Personally I don't think these trucks will get to the Camaro/Chevelle/Corvette, etc. status, but is it worth the chance? |
11-16-2007, 04:10 PM | #7 |
its all about the +6 inches
11-16-2007, 04:12 PM | #8 |
I vote no, Who cares about the frame.
1947 International KB-1 1957 Chevy Bel-Air riding low 1962 swb fleetside 2002 Chevrolet Silverado 7-inch lift on 35 Daily driver 2016 Chevy Tahoe Better halves ride |
11-16-2007, 07:20 PM | #9 |
im not sure about 67/8's but its really hard to see the stamping sometimes with a thin layer of surface rust on it... on my 71 i swear i had to use a wire brush for like 10 mins to make out the numbers
11-16-2007, 07:22 PM | #10 |
11-16-2007, 07:35 PM | #11 |
i know i,am gonna do a c-notch and i got a different frame to modify ( c-notch & cut cross member for exhaust pass thru ) this way i can put the truck back stock and still have original frame with matching numbers.
bob
I BELIEVE IN JOHN 3:16 |
11-16-2007, 08:17 PM | #12 |
Sure won't decrease the value if you swap from a lwb frame to a swb one.
"You can take the man out of PA, but you can't take PA out of the man" |
11-16-2007, 10:05 PM | #13 | |
Active Member
Jack OK I couldn't wait. Longhorn man is right they are not vin #'s. They are "upside down". I did find some #'s where the arrow shows but it was to dark to see them well. More then likly the vin. Jack
68 Chevy Long utility bed. Now swb/Bagged Soon to be 468 (Maybe 496) BB/Turbo 400 Last edited by action; 11-16-2007 at 10:18 PM. |
11-16-2007, 10:47 PM | #14 |
My 68' was stamped on the frame, but on the top of the frame drivers side under the cab. There are other numbers ??? stamped on the sides of the frame about the same location.
Alex 1971 Lil' Red 350 SBC 700R4 |
11-16-2007, 10:58 PM | #15 |
Sure it will decrease the value on a truck that would otherwise be worth good money for being original.Makes it illegal(technically),too.AND,these trucks are every bit as collectible as any muscle car.Just not bringing the same money.But,a well optioned or rarer truck in the right condition can be worth 10X what it did new.
"BUILDING A BETTER WAY TO SERVE THE USA"......67/72......"The New Breed" GMC '67 C1500 Wideside Super Custom SWB: 327/M22/3.42 posi.........."The '67" (project) GMC '72 K2500 Wideside Sierra Custom Camper: 350/TH350/4.10 Power-Lok..."The '72" (rolling) Tim "Don't call me a redneck. I'm a rough cut country gentleman" R.I.P. ~ East Side Low Life ~ El Jay ~ 72BLUZ ~ Fasteddie69 ~ Ron586 ~ 67ChevyRedneck ~ Grumpy Old Man ~ Last edited by special-K; 11-16-2007 at 10:59 PM. |
11-16-2007, 11:31 PM | #16 |
Happy to be here
Lets put this in perspective. If you were looking at a totally restored SS/RS Camaro that everything was #'s matching but the subframe would it hurt the value? No, not at all.
The reality is that some day a #'s matching truck might make a difference, but it doesn't mean much in today's market.
11-17-2007, 12:47 AM | #17 |
If there is a way to identify the frame with the vin, and those numbers don't match, then you have an almost numbers matching vehicle. The numbers do matter.
11-17-2007, 12:51 AM | #18 | |
x2
RIP EastSideLowLife '72 C20 SWB convert. 5 lug, LS1/4l60e |
11-17-2007, 01:09 AM | #19 |
Thanks for all of the input.
The truck is a 68 swb cst 396 with factory tach, fleetside wood floor, and buddy buckets with the spid to prove it. It also has the original numbers matching engine and trans. Only problem is the frame was bent when the guy bought the truck, so it has to be changed. It was a truck I posted about buying a week or so ago. I really want the truck and it comes with a frame that has already been totally rebuilt. I just want to invest in restoring a good truck. As long as I have the SPID, I think the truck should still be worth the resto, right? |
11-17-2007, 08:55 AM | #20 |
Happy to be here
In this case it doesn't seem to matter. Unless you plan to straighten the original frame you have to change it out.
Until Bloomington adds a category for trucks, a properly restored truck with a fresh frame is still going to retain it's value.
11-17-2007, 09:16 AM | #21 |
That`s a tough one.Although some think a vehicle has to be a car or at the extreme high end of value that becomes an investor`s market more than a collector`s,a truck like that is truly a collector`s item and a true truck collector(yes,they exist and have for years)would not want the numbers off in such a major component.It becomes a reconstructed truck.It will still bring high dollar (in the truck world),but certainly reduce the number of interested parties and the price as with any reconstructed vehicle.I wouldn`t let it stop me,just make sure you buy it right.
I hate to see rarer vehicles wrecked and believe in doing whatever it takes to bring it back.I`m comparing apples to apples,not apples to oranges.
11-17-2007, 11:05 AM | #22 |
Saving 1 truck at a time!
That is a truck worth putting all the effort into. I would really look at having the frame straightened at a GOOD frame shop. The frames are really low strength steel and very flexibile. It would be well worth putting a $1000 into that frame to get it right...it is possible.
Let me know if lose interest...LOL!
'68 C20 Longhorn 50th Anniversary 400/TH400 '68 C20 Longhorn 50th Anniversary 468/TH400w/buckets '72 C20 Halfhorn (Longhorn w/o cab and front clip) '69 Flxible Cruiser (look up ugly in the dictionary) Last edited by stllookn; 11-17-2007 at 11:06 AM. |
11-17-2007, 11:11 AM | #23 |
honestlly its a frame if it hasnt been mangled up and the truck has a good title and drives straight nobody would really question it and if its hard to see with everything on it how many people would look at the frame and know what the numbers meant
http://i11.photobucket.com/albums/a1.../DSCN20132.jpg |
11-17-2007, 11:25 AM | #24 | |
Thats the type of truck that is worth trying to keep as original as possible, but a straight nonoriginal frame might be more valuable than a banged up original frame. Have you checked to see if it could be straightened yet? -- that would be the best outcome |
11-17-2007, 11:56 AM | #25 |
"Trucks with Class"
Yes, it is worth more if the title, frame & vin tag #s match. Especially on a top end model. You run into problems when you try to sell it on Ebay, auctions, reputible dealers, and many out-of-state deals.
Unless it is inspected, re-vined and re-titled legally you can't get it into states like CA, WA, etc---legally. If it is just an average run around home truck---who cares. If it is a really nice expensive truck...think about how you are going to do it. Some day you may regret it. |
