Old 11-16-2007, 08:05 AM   #1
thump16
thump16's Avatar
carb replacement
I searched the site but didn't find an exact answer. Do I need any special parts to switch my mangled rochester over to an aftermarket such as holley or edelbrock. my current carb has broken and missing peices from the previous owner. It looks like he tried to convert it to a two barrel by removing the control arm from the secondaries. and the electric choke is busted half way off so it is not fixable at all. The auto stores around here all have rochesters starting at 700.00 and above and that is not in my price range.
Sledge
thump16 is offline   Reply With Quote
Old 11-16-2007, 10:28 AM   #2
swb85
On a budget like Fred Sanford
swb85's Avatar
Re: carb replacement
Your rochester is a spread-bore carb and most aftermarket carbs are square-bore. You'll either need an adapter to mount a square-bore holley/edelbrock on your spread-bore intake, or upgrade to an aftermarket intake with square-bore flange.
'85 Silverado swb: 383 stroker, 10.5:1, vortec heads, 232/238 roller cam, RPM air gap, performer 750 carb, stainless longtubes, 3" duals/super 44's, T56/4.11 383ci build / exterior refresh thread
'98 Camaro z28: 370ci twin turbo 370ci build
'01 Tahoe LT 4x4: 5.3, longtubes/ory, magnaflow duals, custom tune....wife's DD
swb85 is offline   Reply With Quote
Old 11-16-2007, 11:45 AM   #3
chev74
Addicted to Chevy
chev74's Avatar
you may need to modify the throttle cable bracket (just dd that monday), may need to get the ten dollar piece of plastic that will lift the original breather off of the carb about an inch, since it may hit the distributor
chev74 is offline   Reply With Quote
Old 11-16-2007, 01:25 PM   #4
Ivan D.
glamoros piece o' lowlife
Ivan D.'s Avatar
All that, or you can just buy a Holley-rebuilt Q-jet from PartsAmerica for about $130 and call it a day
The more I drink, the more I drink, the more I drink...
diesel, reg cab, long bed, 4 across the rear, single stack, wooden stakes, and lotsa lights - the Hay Express
Ivan D. is offline   Reply With Quote
Old 11-16-2007, 02:34 PM   #5
chev74
Addicted to Chevy
chev74's Avatar
nothing like a beautiful new holley or edelbrock though.....
Old 11-16-2007, 03:00 PM   #6
thump16
thump16's Avatar
what about all those vacuum lines that run across the top and everywhere? Can i axe those as weel? I know some control the accesories.
Old 11-16-2007, 04:06 PM   #7
chev74
Addicted to Chevy
chev74's Avatar
the only vacuum you should still need is for the vacuum advance, PCV, theres a hookup for the brake boosters (if you have power brakes) and another one for something.... cant remember
Old 11-16-2007, 06:46 PM   #8
thump16
thump16's Avatar
okay I brought a holley 600 and the guy swore that it would fit my stock intake with an adapter. The model is 4160c universal. Is this a good model?
Old 11-16-2007, 06:51 PM   #9
chev74
Addicted to Chevy
chev74's Avatar
the holley site says that all the 4160 are for marine application, anyone else getting this info?
Old 11-16-2007, 07:21 PM   #10
thump16
thump16's Avatar
I saw the application chart. here is the link. http://www.holley.com/data/Products/...0pgs.54,55.pdf
