11-16-2007, 05:31 PM | #1 |
Love That '69
Billet Door Handles & Window Cranks
I'm looking at buying these billet door handles and window cranks either off E-Bay or from Billet Specialties. They look a bit better than the stock ones in my opinion and add a custom touch to the interior. Anyone have any experience with these? Any one have them, if you do, do you like them?
I AM CANADIAN!!!!! 1969 Chevy C/10 Truck - SBC V8, TH-350, 3.73 Posi, 1000W Rockford Fosgate Stereo System, B&M Megashifter, GT Grant Steering Wheel, Dual Magnaflow Exhaust System, Dynomax Headers, Lowered 1" Front & 3" Rear, Front/Rear Sway Bars, Racing Seats, 6000K HID Headlights 2008 Chevy Colorado LT - 3.7L I5, 4 Speed Automatic, Crew Cab, 4X4, Z71 Off-Road Package, "Ground Effects" Package, K&N Cold Air Intake, Supermod PTB, Magnaflow Exhaust w/ Resonator, 500W Kenwood / Rockford Fosgate Stereo System, Custom LED Lighting, 6000K HID Low's / High's, Blackcat Customs Gauges / Needles, Carbon Fiber Interior Accents, KrFabs 2" Lift Shackles / Torsion Bar Crank with Rancho RS5000 Shocks, Superskids Skid Plates |
11-16-2007, 06:09 PM | #2 |
Re: Billet Door Handles & Window Cranks
those suck. i cant describe them any better than that. i have them on my truck now. well atleast just one window crank because the other three fell off. the way they mount on with the bolts is a bad design cause they wear out everytime you turn them. they wore themselves out on mine. so after like a few weeks on yours, youll go to open your door and the handle will go all the way around and youll be stuck inside. a few others i know have had the same problem. im trying to find a better set or im gonna machine my own. do yourself a favor and dont buy them. wow that was the most ive typed in a while...
11-16-2007, 06:13 PM | #3 |
Love That '69
Thanks cflvulcan!!! That was exactly what I needed to know. I wasn't too sure if the set screw design on these things were good or not. Now I know I can save my $ and spend it elsewhere on my truck. Just thought I'd ask here first, good thing I did.
11-16-2007, 06:20 PM | #4 |
Insert Title Here
is there a way to just adapt the billet handle to the factory parts that bolt to the door... ive never had a handle off, so i dont know what it looks like
BOBBY _69 SWB_ 1000 pics of 67-72's>> http://s193.photobucket.com/albums/z...-72/?start=all << Last edited by 1LoC10; 11-16-2007 at 06:20 PM. |
11-16-2007, 06:27 PM | #5 |
Love That '69
The stock door handles/window cranks have the spline gears built right into them instead of being a separate piece that is held in by 2 or 3 set screws. The stock handle/crank has grooves on either side (on the back side) and are held on by a press-fit clip. Its been 4 years since I bought new ones and I've never had one fall off or break yet.
I AM CANADIAN!!!!! 1969 Chevy C/10 Truck - SBC V8, TH-350, 3.73 Posi, 1000W Rockford Fosgate Stereo System, B&M Megashifter, GT Grant Steering Wheel, Dual Magnaflow Exhaust System, Dynomax Headers, Lowered 1" Front & 3" Rear, Front/Rear Sway Bars, Racing Seats, 6000K HID Headlights 2008 Chevy Colorado LT - 3.7L I5, 4 Speed Automatic, Crew Cab, 4X4, Z71 Off-Road Package, "Ground Effects" Package, K&N Cold Air Intake, Supermod PTB, Magnaflow Exhaust w/ Resonator, 500W Kenwood / Rockford Fosgate Stereo System, Custom LED Lighting, 6000K HID Low's / High's, Blackcat Customs Gauges / Needles, Carbon Fiber Interior Accents, KrFabs 2" Lift Shackles / Torsion Bar Crank with Rancho RS5000 Shocks, Superskids Skid Plates Last edited by Classic69; 11-16-2007 at 06:32 PM. |
11-16-2007, 06:31 PM | #6 |
[QUOTE=cflvulcan;2448700]those suck. i cant describe them any better than that. i have them on my truck now. well atleast just one window crank because the other three fell off. the way they mount on with the bolts is a bad design cause they wear out everytime you turn them. they wore themselves out on mine. so after like a few weeks on yours, youll go to open your door and the handle will go all the way around and youll be stuck inside. a few others i know have had the same problem. im trying to find a better set or im gonna machine my own. do yourself a favor and dont buy them. wow that was the most ive typed in a while...
I second that.
1968 c10 lowered 3" 4" 355/Th400 built by Hatfield racing in joplin MO |
11-16-2007, 06:34 PM | #7 |
Love That '69
11-16-2007, 07:47 PM | #8 |
Broke and still trying
Those are super flimsy. More like stamped aluminum. If you can find the ones that are solid. I was going that direction and found another set that had the spline cut into the aluminum and was a solid piece.
11-16-2007, 09:21 PM | #9 |
i dont like my door panels but they look better than they used to. just imagine that color orange that accent piece is but the whole door hahahha...
11-17-2007, 10:04 AM | #10 |
Love That '69
That would have been pretty tacky!!!! LOL
11-17-2007, 04:20 PM | #11 |
I have them and they work great. I did have to make them work great though. If you install them right out of the box, then you will be cursing them shortly. What you have to do, is to take a 1/16" drill bit, and slightly drill into the adapter where the billet arm set screw tightens to. If you don't, the set screw from the billet arm will not lock onto the adapter, and will just spin. Then you will say, "These are junk"
I've have them in now since the beginning of last Summer, and never any problems. They only thing I'm not crazy about, is that I wish they were a little larger.
1997 GMC Sierra Ext 1965 Mustang Last edited by 70GMCer; 11-17-2007 at 04:25 PM. |
11-17-2007, 06:10 PM | #12 |
70gmcer, thats a good point. and yeah i wish they were a bit bigger...
11-17-2007, 09:30 PM | #13 |
senior member
seeing as your on ebay looking for them i remember finding alot of different designs for handles and cranks other than what billet specialties and APC offer
69 GMC bagged |
11-17-2007, 09:34 PM | #14 |
senior member
http://cgi.ebay.com/ebaymotors/Bille...temZ4594560678
i like these my self
69 GMC bagged |
