11-16-2007, 06:20 PM | #1 |
Rocker panels
Can anyone tell me about how much it would cost to get my rusty rocker panels replaced? And how hard of a job is it if I did it my self?
11-16-2007, 07:05 PM | #2 |
Re: Rocker panels
christians classics.com has them for 20 each. as for how hard ill find out this weekend
11-16-2007, 07:32 PM | #3 |
Re: Rocker panels
Not too hard if you have a welding machine and know a little bit about body work, do a search on rocker panels there are several good posts on how to replace them.
1971 C-10 2004 Yukon: 1998 Honda Accord 2008 Honda Civic 2004 HD V-Rod http://67-72chevytrucks.com/vboard/s...d.php?t=226458 |
11-16-2007, 08:14 PM | #4 |
Re: Rocker panels
It also depends on how bad everything is once you get it cut apart. So far I have not had a just rocker panel replacement. It always ends up being rocker, inner rocker, kick panel, A post bottom and small areas of the floor. Got any pics?
Kevin LFD Inc. |
11-16-2007, 09:01 PM | #5 |
Re: Rocker panels
Its not that hard to do if you know a little about weilding.Like rokcrin said when you get the rocker off you most likly will find more damage.Just take it as learning experance and go for it.I had never done this before and i did it.It may not come out perfect but I did get rid of all the rust and it looks good.
77 swb starting all over again. |
