Old 11-16-2007, 10:54 PM   #1
swamp rat
swamp rat's Avatar
Mig setting??
I am a total beginner when it comes to body work, but I do know how to weld thick stuff. I have a crack on a floorboard of one of my trucks that I would like to weld up.
I have a millermatic 180. Could some of you recomend a good starting point as far as voltage and feed rate settings? and wire size? I have a 75/25 mix gass bottle.
I have seen a bunch of posts about welding repares but none that included settings and wire diameter..
Mike.
Swamp Rat build thread :
http://67-72chevytrucks.com/vboard/s...d.php?t=595019
72 3/4T 4X4
4" BDS Lift
33" BFG's
swamp rat is offline   Reply With Quote
Old 11-16-2007, 11:39 PM   #2
shifty
Questionable
shifty's Avatar
Re: Mig setting??
This is the wrong subforum to post this question in.
Go post in the Paint & Body forum for better results.
The Projects folder is for start-to-finish build-up threads.
If I've got anything up for grabs, it'll be here: 7-hole gauge cluster for a 67-72 p/u FREE (link)
I can't check the forum daily. If I don't reply to you within 24 hours, drop me a PM! I'm (hopefully) still alive and will reply faster to a PM.
shifty is offline   Reply With Quote
Old 11-17-2007, 12:32 AM   #3
swamp rat
swamp rat's Avatar
Re: Mig setting??
Thanks!
Mods can delete this thread if they see fit..
Mike.
72 3/4T 4X4
4" BDS Lift
33" BFG's
