Old 11-17-2007, 03:11 AM   #1
55dude
55dude's Avatar
60' frame vs 66'
dudes, do 60' frames have different cab mounting points than say 66'? the reason i ask is the 60' has the torsion bar front end vs the standard a-arms on a 63' on up. i have a 59' that is on a 63'-70' frame and have a sweet running RUSTY 60' i was thinking about using under the 59' can anyone tell me the difference? thanks
55dude is offline   Reply With Quote
Old 11-17-2007, 05:17 AM   #2
Stepside65
Still Truckless!
Stepside65's Avatar
Re: 60' frame vs 66'
Dunno bout the cab mounts but i know the bumpers and bed mounts are different between the 60-62 and 63-66
~James
Truckless
2009 Hyundai Sonata<~~Wife's sedanomatic
1997 Nissan Pickup Father-in-law's tonka toy I am forced to drive
Founder of The 60-66 Club
Tutor Et Ultor
Stepside65 is offline   Reply With Quote
Old 11-18-2007, 11:34 PM   #3
Captainfab
60-66 Nut
As already stated the bumpers are different, plus the front cab mounts are different, but just need to drill holes. I believe the rear cab mounts are the same. The bed mounts are different, but there again just need to drill holes. I do believe the radiator support mounts are the same too.
Old 11-19-2007, 09:45 AM   #4
63sbssbbw
UCA63
63sbssbbw's Avatar
while we're on this topic,i have to replace my front cab supports('61 gmc),can i weld in 63-66 supports then mount the cab on a 63-66 frame???
thanks T
member#7816
"63 sb ss bbw 350\350 12 bolt rear Pwr Fr Disc PS tilt
'61 GMC in progress
'63 GMC to use for parts
'90 Chevy Ext cab sbfs 5.7l (current d d)
63sbssbbw is offline   Reply With Quote
Old 11-20-2007, 01:01 AM   #5
Captainfab
60-66 Nut
thanks T
Yes you can...you could also do it with the '60-'62 cab supports....just have to drill the bolt hole. The shape of the front cab supports are the same from '60-'66. They have a double step in them that will work on either the '60-'62 frames or the '63-'66 frames. The difference is the location of the bolt hole for the cab mount assembly.
