11-17-2007, 12:58 PM | #1 |
Gauge question
Guys,
My 67 SWB was an original 6 cyl/3spd "farm truck". I bought it was a 350/400combo. I am going to restore this truck to factory specs on the inside and out, except for the drivetrain. My gauges are just the big three (speedo to the left, gen and oil pressure lights in the middle, and fuel to the right). I have the wiper switch and headlight switch on the upper left and the choke on the upper right corner. I cannot find a new gauge bezel that replecates this. I can find the bezel with the 4 smaller holes on the bottom with the switches set up this way but thats it. I have looked at a few of my catalogs and nothing. I am going to restore the dash and may go with the bezel with the four small holes and put in autometers along the bottom but I was curious about my setup. Thanks Mike
1967 Fleetside, Sanford and Son Special Ivory/Blue Vinyl, 350/TH-400/12-bolt |
11-17-2007, 02:51 PM | #2 |
Old Duffer
Re: Gauge question
Hang on geoman, someone will jump in here pretty quick. I've seen the bezel you need in a catalog, but it doesn't have the light switch hole. One of the board member vendors will be along.
'68 Short C20 Flatbed Dually w/ 292 4bbl, Langdon cast headers, and WC T5 trans. '81 G10 Shorty Van "Good judgement comes from experience, and a lot of that comes from bad judgement." Will Rogers "Under promise, then over achieve." |
11-17-2007, 08:39 PM | #3 |
Re: Gauge question
Geoman, try Truckers in Las Vegas they have the one that you need, I got one for my 68 and they are the same.
WWW.Tuckersparts.com |
11-17-2007, 09:07 PM | #4 |
Re: Gauge question
I have a factory bezel just like that I was just about to cut holes in so I could have the gauges. We could just trade. My truck is far far from stock or am I worried about it. The grey edge has rubbed/faded off and needs to be refinished. Let me get my camera battery up to the task and I will show you what it looks like anyhow.
R.I.P ESLL Even as the body dies the spirit lives on in the people you touched |
11-17-2007, 09:44 PM | #5 |
Re: Gauge question
Here it is with my gauges. They are still out there. My last 68 had one just like it. It appears that the names of the switches are into and onto the bezel. In other words the letters are raised and the bump they are on is also molded all onto the bezel. None of the bezel is replaceable as far as the plastic part is concerned. It is one solid piece of plastic, letters and all.
R.I.P ESLL Even as the body dies the spirit lives on in the people you touched Last edited by DavesRide; 11-17-2007 at 09:49 PM. |
11-17-2007, 10:54 PM | #6 | ||||
Union Electrician
Re: Gauge question
The 67-8 idiot light dash bezel is not being repopped, only availible in 69-72(no choke provision) so you will have to restore your(if you can ) or find a uaable bezel and restore it.
69 Custom-10 SWB FLEETSIDE 350/350 TH Dropped 3.5/5.5" Help support the board->HERE Board vendors -> Vendors list Zip:40272 Big Sandy Survivor... Quote:
11-18-2007, 07:13 AM | #7 |
Re: Gauge question
Dang and I thru away all those lovely 3 hole clusters from 67 dashes.
"Remember, They can Kill You, but they can't eat You, That's against the law!!!!!!!!!" |
11-18-2007, 11:51 AM | #8 |
Re: Gauge question
Thanks for the info. The P.O. painted it red and drilled some holes in the bottom for some cheap aftermarket gauges.
I will either upgrade mine and get the one with all the holes or try and find a good used stock bezel and restore the best I can. Thanks again for the info! Mike
11-18-2007, 04:41 PM | #9 |
Re: Gauge question
Is this what you are looking for?
1972 C20 Suburban- Big Blue Betty '56 Chevy Bel Air Sedan- Frame up Restoration -What would you attempt to achieve if you knew you could not fail?- -I Refuse To Tiptoe Through Life, Only To Arrive Safely At Death's Door- R.I.P. EAST SIDE LOW LIFE |
