Old 10-09-2002, 05:43 AM   #1
super72bb
Conversion Guru's help!
A friend of mine is replacing his stock 2 speed powerglide with a TH400. In his 68 2WD 1/2 ton. He is also changing the stock 6 bolt rear end to a 5 bolt.
My questions are.... what modifications are needed as far as cross member, mounts, or linkage if any. The driveshaft needs to be shortened does anyone know how long the shaft should be off hand. Is there any size difference between the earlier 6 bolt rear end caps (U-joint caps) and the 5 bolt stlye? Or will the same size u-joints work.
If there is any other tips you may have with this conversion to help that would be awesome.
Thanks everyone
1972 CHEYENNE SUPER SWB BLACK. 402 BB, TH400, AIR, TILT, TACH, BUCKETS, CRUISE, AM/FM, 8 TRACK.
My build thread:
http://67-72chevytrucks.com/vboard/s...=1#post7120181
super72bb is offline   Reply With Quote
Old 10-09-2002, 10:11 AM   #2
slam33
slam33's Avatar
Doing a turbo 350 would be a staight in swap, the 400 need a shorter drive shaft, and the linkage package is differant. You also need the 3 speed steering colume, starter might be differant as might be the flex plate. What does he have for a motor. A SBC works best with a Turbo 350 as the 400 will eat about 30 hp to drive it.
71 LWB 350/350still working on it but it's going tp be sweet. www.geocities.com/stevemau/slam33page.html
" TARGET=_blank>http://www.geocities.com/stevemau/slam33page.html?1004806705410
</A>
slam33 is offline   Reply With Quote
Old 10-09-2002, 11:00 PM   #3
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
one thing slam left out on the 400 deal is the yolk. The TH400 has a unique yolk.
Old 10-10-2002, 08:20 AM   #4
Mike C
Mike C's Avatar
U-joints should be same. As noted, TH350 will drop right in place of powerglide. Takes 48hp to turn a TH400 in top gear compated to 35 hp with a TH350 NOT a 30 hp difference, but 13.
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
