Old 11-17-2007, 09:24 PM   #1
1969k10stepside
Thumbs up Success at last
Yep..finally.I got the add-a-leafs sent to me free of charge installed...Ran out of oxygen in the torch and had to get some before I could heat up the clips or what ever you want to call them that holds the springs together,so that I could get the spring pack apart.I got the pack apart,add a leafs installed,and then back on the truck.I got the axle back in place,on go the plates,then on goes the u-bolts,get out the air ratchet and then get to tightening...get it all snug,lower it down,tighten it all down,check the measurements and......the truck now sits 2" higher than it did..pretty much leveling the truck out
I'm still not happy I had to take the front end off,and I've done it so many times now that I could change the front end out as quick as a nascar pit crew could change a tire but I'm glad Rough Country sent me new springs,and these add-a-leafs to level things out..and 2 pairs of hats and t-shirts free of charge
Now,as soon as I get the cab finished up,the body can go back together,I can drive it again,and can get some new pics to show it off
Now,what problems could I possibly face next month installing the lift on the '72 K/5???
1969k10stepside is offline   Reply With Quote
Old 11-17-2007, 11:08 PM   #2
62 short step
62 short step's Avatar
Re: Success at last
Glad things worked out, all the trouble sucks though!!!!
62 short step is offline   Reply With Quote
Old 11-18-2007, 09:47 AM   #3
Yukon Jack
Post Whore
Yukon Jack's Avatar
Re: Success at last
Good to know Rough Country was willing to make it right!
1970 Blazer with a 400 sbc and 4" lift
1980 Pontiac Trans Am, 455 Oldsmobile
2012 Kawasaki Concours 14
Yukon Jack is offline   Reply With Quote
Old 11-18-2007, 01:13 PM   #4
duallyjams
duallyjams's Avatar
Re: Success at last
how about some pics now
James
63 GMC V6 4speed carryall
65 chevy swb bbw V8 auto
68 K20 327/4 speed, buddy buckets
2002 GMC CC Dually Duramax
64 GMC lwb 3/4 V6 4speed SOLD
66 GMC swb bbw buddy buckets SOLD
IG duallyjams
The only thing that stays the same is constant change!
duallyjams is offline   Reply With Quote
