anyone done a Vortec 454 swap?
Well my long overdue project may have taken yet another turn today. I picked up a 2000 Vortec 454 and 4l80e trans complete with all wiring and computer this afternoon. Interested to see if someone has already done this swap.
Anyone know the specs on this engine????
- Greg |
Re: anyone done a Vortec 454 swap?
It should look something like this when installed.
- Greg |
#3 | ||
from http://www.4x4review.com/vehicles/chevy/99suburban.asp
from http://media.gm.com/division/chevrol...engine.htm#l29 Quote:
- Greg Last edited by 454HO; 11-18-2007 at 07:26 AM. |
Windy Corner of a Dirty Street
Well, yes…I am sort of in the middle of that swap now. Marine L29 EFI instead of automotive (C/K truck) L29. Less the 4L80E though.
http://67-72chevytrucks.com/vboard/s...d.php?t=263323
Current vehicle collection: 1978 Chevrolet K10, 8.1L, NV4500, NP205 1989 Chevrolet Suburban, 8.1L, NV4500, NP241 1993 Chevrolet C1500 Sportside, TBI 7.4L, 4L60E 2001 Chevrolet K2500HD, Ext Cab, SWB, 8.1L, ZF 6 speed 2014 Chevrolet Impala LTZ 3.6L Vortec 8.1L because life is too short to tolerate underpowered vehicles
#5 | |
Well Larry, I guess we are the pioneers for this engine here on this forum.
- Greg |
#6 | |
After a bit of on-line research, I've discovered the Vortec 7400 L29 motor uses the same cam as the 502HT crate motor.
references - http://www.sallee-chevrolet.com/Chev...f/88890533.pdf http://www.gmperformanceparts.com/En...0534&engCat=bb http://paceperformance.com/index.asp...D&ProdID=43577 Quote:
http://www.dieselpowermag.com/towing.../photo_09.html ![]() Since I do not plan to pull up stumps with this truck, I will definately be swapping in a different cam to bumb the HP up a bit. Not sure if I should just get the engine installed and running first, or go ahead and swap the cam while it's out. Anyone know how much lift the stock Vortec heads can handle before the valve keeper bottoms out on the guide?? Hmmm I've got a set of 781 heads I could use...
- Greg |
I know a guy who did this swap but carbed it he put it in his truck. Its a k20 '84 turbo 400 36" tires and six inches of suspension lift. He hooked it up to a pulling sled and it pulled 292 feet at a 300 foot track.
-Lincoln 1987 GMC S15 (soon to be a chevy clone) ![]() 2.5l, 4 speed, no ps, no pb, no ac Silence is golden, but duct tape is silver. ![]() Spoken by Cletus the hillbilly I like stickers... a whole bunch. |
#8 | |
I've decided I will leave the engine stock for now and just drop it in the truck. I'll use the Headman Elite headers I already have, then get an aftermarket air intake setup and a custom tune flashed in the PCM. That should put me real close to 350HP with gobs of torque from off-idle to 4500rpm or so. The 4l80e trans with stock locking torque converter and a 3.42 posi rear end should let me get pretty decent fuel mileage and still have a lot of fun.
- Greg |
#9 | |
#10 | |
K5Camper
![]() Join Date: Mar 2004
![]() ![]() ![]() Just bustin your balls Larry! Order your plumbing parts already so we can get that beast running!
Rob Z. 1975 K5 350/465/205/D44/12b 4" lift on 35's- RIP 1991 K5 8.1L/NV4500/241/D44/14b FWC Camper Last edited by Zoomad75; 11-21-2007 at 05:10 PM. |
I realize you are going with the EFI set up. I was telling you how much power you can get out of a completely stock motor.
