Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Tools, Shops and Shop Safety
Old 11-18-2007, 02:43 PM   #1
5150
C10 Club Tennessee
5150's Avatar
Building a Garage
Hey guys,
About to start on a 30x40 garage unattached garage. I want a lift in it, but need to make sure that I go with the right height. How high should I go or what is the minimum I need to go to still have a lift???
Bryan
www.gmtruckshow.com
Project "Andes"-Halen's First Truck
Project: Patina Burb
for he is God’s servant for your good. But if you do wrong, be afraid, for he does not bear the sword in vain. For he is the servant of God, an avenger who carries out God’s wrath on the wrongdoer. Romans 13:4
5150 is offline   Reply With Quote
Old 11-18-2007, 03:58 PM   #2
PanelDeland
I am a Referee of life.
PanelDeland's Avatar
Re: Building a Garage
Hey, Brian go over to www.garagejournal.com you will find more info than you can absorb and some facts about types of lifts and such.They ain't quite as cool as 67-72 guys but they are working on it.They even use a layout pretty much like this so it's easy to learn to navigate(If I can anyone can)There is also a wealth of info on organization and storage options.Plenty of info on wiring,plumbing,air lines,and other shop tips and equipment.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion.
You can't fix stupid,not even with duct tape.
"My appearance is due to the fact that "GOD" does punish you for having too much fun!"
Barrett-Jackson has perfected alchemy,they make rust into gold!
"You can lead a horse to water but you can't saddle a duck"
"Cleverly disguised as a 'Responsible Adult'
"Sometimes your Knight in shining armor is just a retard in tinfoil"
PanelDeland is offline   Reply With Quote
Old 11-18-2007, 04:05 PM   #3
NONHOG
NONHOG's Avatar
Go to sites that sell lifts , my memory sucks but I think I recall ones that advertised lifts for 10 ft walls . but study up ! good luck on your garage!
"I feel the need for speed!"... as soon as I am done with my nap.
NONHOG is offline   Reply With Quote
Old 11-18-2007, 08:18 PM   #4
streetstar
streetstar's Avatar
12'. to be on the safe side --- i have been throuh this already myself
streetstar is offline   Reply With Quote
Old 11-18-2007, 08:45 PM   #5
PanelDeland
I say use 22 ft walls.That should cover your 30X40 garage and give you about a 24X40 man cave loft.If you have that big a shop you may need to spend some time out there.
Old 11-18-2007, 08:49 PM   #6
Lemondrop63
Lemondrop63's Avatar
We have a 35 x 55 with 12' walls. We have a lift that works great with all cars and trucks.
This one time at bandcamp, in my c10, I ran over the girl hiding the flute!
http://67-72chevytrucks.com/vboard/s...d.php?t=255141
Lemondrop63 is offline   Reply With Quote
Old 11-18-2007, 10:38 PM   #7
See how high your truck is from the bottom of frame-up*,add your height and what would be a good reach to your floorboard.Add more for ceiling clearance.I`d think about 14-16 feet
*or bottom of tires,depending on lift design.Whatever will sit on the lift.
Old 11-19-2007, 12:01 AM   #8
earl87gta
earl87gta's Avatar
Im voting 14 unless you can volt it and have the lift in the center of the garage. my lift and 12 walls didnt work so well with a big truck onit. I still had to duck when it was up all the way.
Earl
68 2500 4x4 GMC Burb
earl87gta is offline   Reply With Quote
Old 11-19-2007, 12:25 AM   #9
Andy4639
Old member
Andy4639's Avatar
Measure your truck from floor to top of the highest point which should be the cab. Then add your hieght & reach to that. This should get you about the right size walls. You may want to add a couple of feet for good measure.
You could always put the top floor in as a trap door's to open when you need the room.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver
Seeing the USA in a 71
Upstate SC GM Truck Club
2013,14 and 2016 Hot Rod Pour Tour
http://upstategmtrucks.com/
Get out and drive the truck this summer and have some fun!
It sucks not being able to hear!
LWB trucks rule, if you don't think so measure your SWB!
After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs.
Andy4639 is offline   Reply With Quote
Old 11-19-2007, 07:00 AM   #10
72freak
Rottenwood Garage Member
72freak's Avatar
To get a lift that you can raise high enough for a 6' person to stand under the vehicle without having to squat.........you will need at least 12'.
15-16' high ceilings give you plenty of room and will allow for a loft you can stand in if you decide to build one..
Now...........if that is too much $$$$$............12' would be your minimum!!!!
Mine are just over 16'............with the lift I have there is 6'3" under the vehicle.
2004 Chevrolet Suburban C1500
2001 Chevrolet 2500HD Crew 6.0
1999 Harley Davidson Electra Glide
1972 Chevrolet C-20 Custom Camper "Dump Truck"
1972 Chevrolet C-20 Suburban "Big Green"
1969 Chevrolet C-50 Wedge Hauler "Leonidis"
1966 C-10 2x4 short fleet 327 4 speed "Race Truck"
1952 Plymouth Cranbrook "Rican" (my grandfathers)
1931 Ford Model A Coupe "Black Beauty"
1930 Ford Model A truck "Club Cab" 4x4
Rottenwood Garage and Speed Shop.....where everything must be racy!
It's not just a hobby..It's a LIFESTYLE!!!
Thanks for nothing Barrett-Jackson
You cant fix stupid or teach accountability!
Time wasters, looky Lous and tire kickers are everywhere!
72freak is offline   Reply With Quote
Old 11-19-2007, 09:52 AM   #11
earl87gta
earl87gta's Avatar
72freak
Nice garage you have there.
Earl
Old 11-19-2007, 12:00 PM   #12
5150
C10 Club Tennessee
5150's Avatar
Well, I'm 5'10, but all of my trucks are lowered So that won't be a problem. I'll see what it costs to go to 14 foot. I got a price on delivery and setup yesterday. Concrete, electrical, and insulation seperate.
Bryan
www.gmtruckshow.com
Old 11-19-2007, 06:33 PM   #13
72freak
72freak's Avatar
Originally Posted by earl87gta View Post
72freak
Thanks.......its a work in progress!!!!!!!
Old 11-20-2007, 04:45 PM   #14
72BlckButy
Tot Roddin'
72BlckButy's Avatar
garagejournal.com is loaded with helpful info. Good luck on the build.
-Nate
1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6)
1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior)
2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package)
72BlckButy is offline   Reply With Quote
Old 11-20-2007, 05:28 PM   #15
piecesparts
Parts and more parts
piecesparts's Avatar
Included is a poor picture, but I have an 8000# Rotary Two Post lift. The ceiling is 12' high and there is more than enough clearance between it and the ceiling. As you can see my ceiling is finished and there is still plenty of room. The Rotary lifts have two height settings (one is for an 11' ceiling and the other is the 12'). I am glad that I chose the 12' height, because I can easily stand under my lift and work. OF course, this lift thing leads to other problems. You will have to spend more money for the right tools, such as a drain hub for oil changes, and a post style tranny jack. No fun having a lift withouthe right tools.
piecesparts is offline   Reply With Quote
