Old 11-18-2007, 04:27 PM   #1
bad_turbo
turbo enthusiast
bad_turbo's Avatar
Question Adding a 3rd seat
just picked up a blazer rear seat to add to my burb as the 3rd seat. Anything I need to know about mounting it for safety reasons or just drill some holes and throw in some grade 8 bolts?
"But daddy, I didn't hit them all with a stick"...what my 6 year old tells me when I pick him up from school early for fighting "
bad_turbo is offline   Reply With Quote
Old 11-18-2007, 07:26 PM   #2
zeusflash
zeusflash's Avatar
Re: Adding a 3rd seat
I also would like to hear from someone who has done this since this project is in my near future. I am also installing the narrow 2nd row seat.
'69 3/4 ton 427 CST Pickup
'71 CST Blazer
'72 GMC 3/4 4x4
zeusflash is offline   Reply With Quote
Old 11-19-2007, 12:00 AM   #3
sbrban
There should be some holes, or at markings of where they would go, on the floor to mount the brackets.
Do you have all the correct brackets?
you never have too many suburbans....
sbrban is offline   Reply With Quote
Old 11-19-2007, 02:44 PM   #4
bad_turbo
turbo enthusiast
bad_turbo's Avatar
I have the correct brackets but my burb never had a 3rd seat in it before.
Old 11-20-2007, 07:54 AM   #5
72GMCburban
72GMCburban's Avatar
Well, I can tell you that the existing rails are either too close to the 2nd row or too close to the back. The gas tank is in the way of inserting a bar/rail for the perfect position. Instead of dropping the tank and going through all that, I just mounted the rear brackets of the bench to the rear most rail. I am assuming you want to mount through some steel and not just the plywood.
72GMCburban is offline   Reply With Quote
Old 11-20-2007, 11:44 AM   #6
OldCreek
OldCreek's Avatar
If you go through the wood place some wide washers or plate on the bolt head to distribute the load to a wider area.... so as they don't rip through during an accident. Thats essentially how it looks like the factory did it. (Large metal plates with threaded nuts/heads screwed into the wood)
1972 K20 Suburban 5.7/700r4/NP205 Dana 44/H052 Sold
1972 C10 5.3L/4L60E 12bolt 5Lug - Sold
1971 K5 Blazer 6.0L LQ9 4L60E NP205 Dana 44/H052!!!
1970 K3500 1ton CrewCab 8.1L/Allison1000/NP205 Dana 60/14B!!!! - Sold
1984 K10 SWB 7.4L/4L80e/NP208 Corp 10/12 bolt Sold
1988 V30 CCLB 7.4L/TH400/NP205/Dana 60/Dana 70/3.73!!! (Sold)
2003 K2500HD 8.1/Allison1000/NP263
OldCreek is offline   Reply With Quote
Old 11-20-2007, 05:47 PM   #7
bad_turbo
turbo enthusiast
bad_turbo's Avatar
I figured I could just drill through the wood and use a piece of flat iron to run the length of the seat underneath to attach all the bolts to.
Old 01-20-2008, 09:40 AM   #8
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Have you done this yet? My assembly manual indicates the holes are there with plugs in the plywood
Old 01-20-2008, 10:37 AM   #9
bad_turbo
turbo enthusiast
bad_turbo's Avatar
I have not done this yet. I will have to look for the plugs next time I'm in cali, since that is where the burb is.
Old 01-20-2008, 01:45 PM   #10
Hart_Rod
Hart_Rod's Avatar
Here's some not so good pictures of the bottom. The front of the seat is bolted to the floor with 2 very expensive "c" brackets. They bolt to nutserts that are nailed to the bottom side of the floor. The back of the seat bolts to the metal brace underneath. I believe the seatbelts bolt to the same brace.
R/
Hart_Rod is offline   Reply With Quote
