Old 11-18-2007, 06:38 PM   #1
nicktheknife
wood bed replacement
Do you have to completely remove the bed from the frame to replace the wood and metal strips?
nicktheknife is offline   Reply With Quote
Old 11-18-2007, 06:54 PM   #2
68MoneyPit
Re: wood bed replacement
would make it a whole lot easier. There are only 8 bolts holding it down
68MoneyPit is offline   Reply With Quote
Old 11-18-2007, 07:15 PM   #3
BAD4X4
BAD4X4's Avatar
We did when we redid ours. It's a lot easier becasue you can out it a little higher off the ground and you don't have to work around rear ends etc.
1972 Cheyenne K-30 6"lift {502 PROJECT}
1972 Cheyenne K-30 8"lift 454 450hp {Ol'Blue}
1972 Cheyenne K-20 Custom Stretch 6" lift 454
1972 Custom Deluxe K-20 4" lift
2007 GMC Crew Cab Diesel 6"lift {The Tow Rig
2017 Ford F-350 Crew Cab 6.7 6"lift (Wife's)
1977 El Camino SS Grandpa baught new
1986 K-30 Crew Cab 502
1955 Chevy 2-Door gasser 454 550hp{project}
1956 Chevy Bel-Air 2-Door hardtop 572 700hp
1979 Ford F-350 All Original 4x4 (Wife's)
BAD4X4 is offline   Reply With Quote
Old 11-18-2007, 09:40 PM   #4
Richard Dobson
It would be a lot easier to go ahead and remove the bed also because of all the carriage bolts you have to remove and replace for the strips, bedsides etc. Reaching up through the driveshaft, rear axle, trailing arms etc. would be very annoying. It's pretty well impossible to get the boards in between the cross sills and the bedsides, wheel tubs etc. without removing it.Get four budies to help take it off and set it on saw horses, you can rest it on the bottom of the front bed panel and the rear cross sill. The saw horses need to have wide boards on the top of them to keep the bed from shifting off of them. Most saw horses have a 2x4 main beam which isn't wide enough to allow much surface for supporting the bed.
Richard Dobson
Richard Dobson is offline   Reply With Quote
Old 11-19-2007, 03:49 AM   #5
EAST SIDE LOW LIFE
EAST SIDE LOW LIFE's Avatar
A picture of your truck would be nice. What shape is your box in? Has it been repainted or does the box need body work and paint? Do any of the cross bars need to be replaced? I'm assuming the box is in some need of paint or repair if the wood bed floor is original. If you can answer yes to most of these questions I would remove the box. I prefer to install the new wood with the box back in place on the truck.
esll.
Pic's 1 through 5 ....
i.) new cross bars installed
2.) Installing wood floor
3.) new cross bars painted [fabricated locally]
4.) heat shields installed
5.) finished floor installed
Tomorrow is for doing today's stuff.
This truck has just the right amount of energy for me!
Author: Warren Lake .... (member)
EAST SIDE LOW LIFE is offline   Reply With Quote
