Old 11-18-2007, 07:19 PM   #1
lolife99
67-72 parts collector,…
lolife99's Avatar
Jan. '08 SPORT TRUCk magazine has a 4wd to 2wd article,...
Just got the new January '08 issue of Sport Truck magazine. Inside is a quick article about converting a 4x4 blazer, to 2wd. I know there is alot of interest in this so I thought I'd post this. Pretty informative and the swap was done by ECE, (Early Classic Enterprises).
Keith
Convert to disc brakes.
Old 11-18-2007, 07:27 PM   #2
NTR72GMC
2wd FTW!!!!
NTR72GMC's Avatar
Re: Jan. '08 SPORT TRUCk magazine has a 4wd to 2wd article,...
What Year Blazer Did They Convert?
NTR72GMC is offline   Reply With Quote
Old 11-18-2007, 07:54 PM   #3
lolife99
lolife99's Avatar
Sorry,... It 's a '72. They do only 4 color pages,... but they convert to trailing arms with the ECE "drop trailing arm" crossmember, factory front crossmember, dropped approximately 4.5" in the front and air bags on the trailing arms in the back. Pretty quick article and they left the engine hanging on a hoist in between the frame rails the whole time. I'd scan it,... but the scanners toast. Maybe someone else can???
Keith
Old 11-19-2007, 05:17 PM   #4
vtblazer
vtblazer's Avatar
What did ECE give as a total cost?
vtblazer is offline   Reply With Quote
Old 11-19-2007, 07:24 PM   #5
lolife99
lolife99's Avatar
They didn't. I did learn that ECE sells used parts also. They used their traiing arms, and drop crossmember, rear air suspension, transmission crossmember and all their front parts including sway bar and drop brackets. They say if you want to save money,... you can just flip the 4x4 rearend on the factory leaf springs and go with a 6-lug rotor on the front. I suggest calling them. Makes me want a clean 4x4 to cut up. Hmmm,...
Keith
Old 11-19-2007, 08:58 PM   #6
bouncytruck
SKINNY TIRES RULE!
bouncytruck's Avatar
Dang, I was thinking about suggesting a how to on this and let them use my Blazer as the conversion truck (free labor?). I guess I'll just have to pickup the magazine.
bouncytruck 1972 K5
The Hauler 1994 K1500 Suburban
The Daily2010 Kia Soul
Wife's Ride2014 Fiat 500L
bouncytruck is offline   Reply With Quote
Old 11-19-2007, 10:27 PM   #7
gringoloco
A guy with a truck
gringoloco's Avatar
Unfortunately there is little detail- mostly just an ECE ad. Most of the details needed to actually pull off the swap were left out, but pretty cool that they did it...
-Chris
Instagram _elgringoloco_
'70 Short-Wide How to: Ruin a perfectly good C10
‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd
'72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD)
'72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD)
'05 Yukon Daily Driven (not so stock) Yukon (SOLD)
‘07 Yukon Denali (daily)
Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy
gringoloco is offline   Reply With Quote
Old 11-21-2007, 12:54 PM   #8
70rs/ss
70rs/ss's Avatar
It is very easy to do it, especially with their trailing arm crossmember. The front bolts in with you having to drill a couple of holes, unbolt, cut leafs out and slide 2wd crossmember in and drill then bolt, the rear I would assume is just as easy. My friend has done several of these, as 2wd are a bit more $$$ than a 4X4.
70rs/ss is offline   Reply With Quote
