Future TOTM Winner
Dumb temp gauge question…
I looked around a little but couldn’t find an answer. Exactly what temperature values do the vertical lines represent on these original temp gauges?
72 Chevy CST K5 HIGHLANDER BLAZER Getting a 6.0,NV4500,NP205,14BFF (Currently laying all over the place in little pieces) 72 Chevy swb step-side "LS" 6.0 Here's a build thread of sorts 2002 HD2500 Crew Cab, 8.1L Allison 4x4 Daily Driver Check it out www.lsdyno.com |
Re: Dumb temp gauge question…
A little less cooler and a whole lot hotter? As long as you're in the middle you're o.k. See you guys on Sunday.
#3 | |
Future TOTM Winner
Those things are 1 step above idiot lights, imo...
'67 SWB Fleetside ZZ4/350/Tremec 5-speed/4link/Scott's IFS - and fun as heck! SOLD ![]() Click here to support the board Philippians 4: 6-7 |
Post Whore
![]() Join Date: Feb 2000
Critter, grab your wife's meat thermometer from the kitchen and put it in the radiator and what the guage and it. I find these gauges vary from truck to truck. My K5's gauge is very near the right side when the temp is actual 180, while my 69's was about in the middle at 180.
1970 Blazer with a 400 sbc and 4" lift 1980 Pontiac Trans Am, 455 Oldsmobile 2012 Kawasaki Concours 14 |
![]() Join Date: Jul 2003
At 180, my gauge is just over 1/4 above the C mark. The oil pressure gauge is right on.
1970 K/5 Blazer CST 4WD, Bronze, 93k ACT. miles, 350, 4 speed, positraction, 16.5" x 8.25" wheel option, tilt, tach, vacuum, AM/FM, manual throttle...Dad ordered and purchased new 4/70. Currently frame off restoration in progress... ![]() 1972 Cheyenne Super 20 2WD, DK Blue/White, 90K ACT. miles, 402, TH400, 4.10 open, tilt, tach, vacuum, A/C, AM/FM, manual throttle.. A mostly original paint never rusted Texas survivor... ![]() 2017 Sierra 1500 SLT 4WD, Black, 41k miles, 5.3, 6L80E, 3.42 LS, 20" polished wheels, everything but moonroof and 6.2... 2019 Canyon SLT 4WD, White, 60k miles, 3.6, 8L45, 3.23 LS, 18" wheels |
It depends on your temp sender. I melted one in the Fox and it shorted itself out reading all thew way hot. The replacement couldn't go pat 1/2, so I got another. I'm sure there are different temp ranges like thermostats, but the guys at the parts counter couldn't tell me which was which. I can play with mine on the Fox because the radiator fans are on a manual switch. With my current sender and a 190 thermostat, the needle hovers about 1/8" pat that first hash with the fans on.
'72 K5, known as 'the Fox.' |
