Old 11-18-2007, 09:28 PM   #1
bad6772
Official Site Guitar Shredder
bad6772's Avatar
Tranny?
was driving home today , in my trusty ole 67 and my (3speed) trans starting making a weird noise ? while in 1st gear letting out on the clutch it makes a noise like something is hitting the bellhousing? and also does this in 2nd gear and i get a small vibration while in 2nd? when i shift to 3rd its as smooth as glass ..the noise goes away when the clutch is pushes in..i just put a clutch in it last year and i am pretty easy on it as far a burn outs or dumping it..goes...my step dad says its a throw out bearing...any help would be awsome.......tony
bad6772 is offline   Reply With Quote
Old 11-18-2007, 09:42 PM   #2
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Re: Tranny?
I would look real hard at all the motor mounts
Old 11-18-2007, 09:45 PM   #3
bad6772
bad6772's Avatar
Re: Tranny?
will do Andy....<this would include the tranny mount also? would a throw out bearing make a noise? it may sound dumb but i swear it sounds like its coming from under the floor.....EDIT...may sound like im stupid but when i got my clutch kit from napa it didnt include a throw bearing ,and the truck only had 56,000 original so ,being it was my only D.D at the time i just put it all back together...it has 89,000 on it now...
Old 11-18-2007, 10:17 PM   #4
Longhorn Man
Re: Tranny?
shoulda got a pilot bearing too.
While it is probably the clutch or in the tranny its self.... a messed up mount (tranny mounts too) can make lotsa funny noises too.
Old 11-19-2007, 06:25 AM   #5
bad6772
bad6772's Avatar
Re: Tranny?
yeah i know i shoulda. lol i swear i usually dont do things like that.. i gota run to gmc pauls today..and when i gets back ill check her out...thanks again......tony
Old 11-20-2007, 03:05 PM   #6
bad6772
bad6772's Avatar
Re: Tranny?
well i checked the trans and engine mounts ? all look fine . so im back out to look at the fluid level and anything else i coulda missed...
Old 11-20-2007, 04:27 PM   #7
Longhorn Man
Re: Tranny?
talkin to you on the phone now let us know what happens
Old 11-21-2007, 07:53 AM   #8
68C15
blood type; Retumbo
68C15's Avatar
Re: Tranny?
sounds to me like a problem in the bearings for the counter shaft. (it goes away when it is in 3rd)
68C15 is offline   Reply With Quote
Old 11-21-2007, 02:43 PM   #9
bad6772
bad6772's Avatar
Re: Tranny?
yeah its gone in third...so? talked to longhorn man last night and did his suggestions.. i cant find anything wrong outside.as far a mount or anything..so im thinking its internal.? i got some things working on a used one. a buddy of mine has a good 4spd that came out of an 82 1/2 ton..so im thinking i might go this route if i can...few questions... assuming they are the same length ? <i havent see it yet> can i used the same clutch and bellhouseing? also is the tranny crossmember the same? is this a common thing to change? 3sp to 4? i have heard that i will have to use the rear yoke from the 4 spd as the splines are differnt? andy help would be awsome......tony....
Edit: thanks Andy for letting me bug ya.......and calming me down a little the day before....
