Old 10-09-2002, 10:41 AM   #1
chevyman02
non a/c cab convert?
Can you fabricate the ac vents in a non air cab? What do you guys do in this situation? Or would it be best just to have the ac vents come out under the dash? Is that an option?
Thanks for your help.
Adam.
chevyman02 is offline   Reply With Quote
Old 10-09-2002, 10:52 AM   #2
1971Stepside
Almost Satisfied
1971Stepside's Avatar
A sawsall and your there. You can easily cut the holes in your existing dash to work. My current dash has been done that way, but I plan to take that dash out and put in an A/C cab dash from a doner truck.
Hold up the vents and trace a circle and then say a small prayer and begin cutting. For the one above the radio I did a lot of measurements from an A/C dash first.
1971 C10 Stepside. LSx 6.0 with BTR Stage IV, Speed Engineering Headers, 4L80e transmission w/3200 Circle-D Stall. 3.73. Posi. Purchased this truck when I was 17. I started the rebuild (or take apart) in 1993. I have drug it around all over the country in pieces. Finally back on the road in 2021.
"I can't complain, but sometimes I still do. Life's been good to me so far."
1971Stepside is offline   Reply With Quote
Old 10-09-2002, 11:45 AM   #3
Hutch
Hutch's Avatar
Lots of different ways to go about this.
Yes there are underdash vents.
To use original components you will also have to modify your firewall.
I would check in vintage airs system for trucks without original a/c
http://www.vintageair.com/
Also check old air:
http://www.oldairproducts.com/
When you add it all up you will get a better performing system.
John Hutchison
Grapevine,Texas
68 1/2 t swb
68 Mustang
69 Jaguar
71 1/2 t swb
88 Supra CompTs6m
93 Escort GT
2005 Corolla XRS
Hutch is offline   Reply With Quote
Old 10-09-2002, 11:55 AM   #4
1971Stepside
Almost Satisfied
Hutch, what do you have to modify on the firewall. I don't remember having to do anything on my firewall, but I was 17 when we did this and my Dad may have made the fix while I was talking to some girl on the phone.
Old 10-09-2002, 12:28 PM   #5
Hutch
Hutch's Avatar
I was referring to adding factory a/c to a non a/c cab.
There is a extra vent hole for the condensor to let the cold air into the cab, some one stated that you could add these by drawing out the pattern on a a/c cab and the use that as a pattern for the non a/c cab.
If you look at the two cabs(a/c and non a/c) without the heater box installed you will see the difference.
Order on of the new systems for a non a/c truck and let dad install it for you, while you take care of business
John Hutchison
Grapevine,Texas
68 1/2 t swb
68 Mustang
69 Jaguar
71 1/2 t swb
88 Supra CompTs6m
93 Escort GT
2005 Corolla XRS
Old 10-09-2002, 12:34 PM   #6
1971Stepside
Almost Satisfied
Well, I will have to check that out and see if I have the extra hole or if I need to add it. Dad has been gone a few years now so it is up to me.....and besides my wife doesn't let me do that anymore with anyone but her.
Old 10-09-2002, 07:04 PM   #7
Hutch
Hutch's Avatar
Does that mean she use to let you get away with it?
Anyway as the hole in the firewall this is the one I was referring to:
Does your cab already have a/c?
John Hutchison
Grapevine,Texas
68 1/2 t swb
68 Mustang
69 Jaguar
71 1/2 t swb
88 Supra CompTs6m
93 Escort GT
2005 Corolla XRS
Old 10-09-2002, 09:43 PM   #8
Rod
Here's a pic of a non ac firewall.
Senior active founding member.
70 3/4 ton GMC Suburban 4x4 250/4 spd.
71 1/2 ton Suburban Chevy 4x4, 350/350
72 Chev 1 ton tow truck 402BB w/Holmes 440 wrecker on propane
2005 FLSTSCI Harley Springer
85 FXSB Harley Lowrider
72 Triumph 650 Bonneville 5spd
"Poor people don't have hobbies" Quote from wife.
Rod is offline   Reply With Quote
Old 10-09-2002, 09:52 PM   #9
1-PU70
1-PU70's Avatar
When I did mine I used a non AC 70 cab and both holes were there. What belive to be true is all 70 to 72 cabs have both holes and 67 to 69 dont. I wouldnt bet my life on it. Just what I have found.
1970 CST/10 402,700R4,3:73 posi,AC,PS,PB,TLT,PW,Buckets with heaters
1-PU70 is offline   Reply With Quote
