![]() Join Date: Apr 2004
Can I get my blazer body to turn WITH the suspension?
Beside calibrating my carburetor today, I also installed a 1.25” front sway bar on my blazer.
'72 2wd blazer, bagged w/ watts link & EDC '72 C10 "Lowered Farm Truck" STOLEN 5-18-11 '66 impala ht |
Re: Can I get my blazer body to turn WITH the suspension?
Yep I have one on my 71 (orange one) that is an old style and it goes in front of the diff. The ends attach tward the the front of the vehical and the rear cross bar attaches to the trailing arms. I don't remember were it came from
![]() Kevin LFD Inc. |
Thanks Kevin. Do you think it will work with bags without modifying my frame. It looks like there might be clearance issues.
I have seen a couple of these. Both of them were on stock trailing arm suspension (one sprung and one bagged) and stock frame. They both were like Kevin's, but mounted across the bottom of the trailing arms. So my answer would be yes, it will work with stock frame and bags.
68 Chev SWB 2WD w/'95 LT1, 6spd, 4:56, 17" whls - family owned since 1973. 70 GMC LWB 4WD w/RAMJET 350, 4spd, 4inch lift, 33" tires, Warn Winch 72 Chev Blazer CST, 350, TH350, 4WD, factory A/C, tilt, radio delete, 77K miles, orig. paint/interior |
A guy with a truck
You can use the Camaro Z28 bar. My buddy has one on his '66 pickup bagged w/ trailing arms. I think either Frizzle Fry or Hart_Rod(maybe both) are using this bar as well- both bagged. I've got one in the garage I plan on using someday...
-Chris Instagram _elgringoloco_ '70 Short-Wide How to: Ruin a perfectly good C10 ‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd '72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD) '72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD) '05 Yukon Daily Driven (not so stock) Yukon (SOLD) ‘07 Yukon Denali (daily) Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy |
![]() Join Date: Aug 2005
Link in sig
Yep. Front and rear.
KEEP ON TRUCKIN'
![]() Join Date: Jun 2005
What year Camaro bar did you use Frizzle Fry?
JIM '97 GMC Sierra K1500 '95 Chevy Silverado C1500 '71 Cheyenne Z71 / LT1 & 4-Speed SWB K/10 ![]() http://www.youtube.com/watch?v=4l689JKXPnA http://67-72chevytrucks.com/vboard/payments.php "LIVIN' FREE FOREVER" ![]() |
I would suggest letting the air out of your bags and looking to see where there are clearances that will allow you put the anti sway bar in. I would think you might have to mount it closer to the rear end depending on how low your truck sits.
Frank
70 chevy lwb c10 454/th400 and a 9" rearend suicide doors, marker light fuel fill, 4" cowl , mini tub |
According to the text he used a 2001 camaro rear bar 19 or 21 mm I have a front sway bar from a 1998 thats really fat (1 3/8 fat!) that i'm going to try and use on the rear. It's really wide so I need to measure everything out and see if it will work and figure out bracketry. Might be to big for the rear though. Frank
