11-19-2007, 01:38 AM | #1 |
Oversized moog ball joint
I got a new moog ball joint to replace the crappy cheap one I got from summit. The one from summit fit fine, but when I went to install it, it was the wrong size for the spindle (ECE drop spindle) and the shaft spun. So I go to install the new moog ball joint (K6117T) and it doesn't fit the hole. I can put it in place by hand and then it just falls out.
I was told there are some oversized ones for just this problem...but can't find the parts number...or the one I got is the oversized one. I don't know, but I need a ball joint. My other option is to pull the control arm off the 3/4 ton parts truck, but I don't know if the control arm is different than the half ton, or if the ball joint is the only difference. Plus I'd have to sandblast and paint the control arm. I'd rather just get a bigger ball joint. |
11-19-2007, 06:42 AM | #2 |
Re: Oversized moog ball joint
I had the same problem when I dropped my son's 72 burb.I had a machinist make bushings that he pressed on the ball joints,then I pressed them in the control arms.It works great.I told him to save his cnc program in case I [or anyone else] had the same problem.I'm not real sure but I think they'll also work for changing 8 lug to 5 lug disc.
11-19-2007, 06:45 AM | #3 |
Rottenwood Garage Member
I put new ones on my 1 ton.........They were bigger. Have you tried that size?
I will get the Moog part # of the box later today
2004 Chevrolet Suburban C1500 2001 Chevrolet 2500HD Crew 6.0 1999 Harley Davidson Electra Glide 1972 Chevrolet C-20 Custom Camper "Dump Truck" 1972 Chevrolet C-20 Suburban "Big Green" 1969 Chevrolet C-50 Wedge Hauler "Leonidis" 1966 C-10 2x4 short fleet 327 4 speed "Race Truck" 1952 Plymouth Cranbrook "Rican" (my grandfathers) 1931 Ford Model A Coupe "Black Beauty" 1930 Ford Model A truck "Club Cab" 4x4 Rottenwood Garage and Speed Shop.....where everything must be racy! It's not just a hobby..It's a LIFESTYLE!!! Thanks for nothing Barrett-Jackson You cant fix stupid or teach accountability! Time wasters, looky Lous and tire kickers are everywhere! |
11-19-2007, 11:14 AM | #4 |
"Trucks with Class"
Moog actually makes an oversized BJ, just for that purpose. Check with your autoparts store. They are very common.
11-19-2007, 01:55 PM | #5 |
got the parts number?
11-06-2010, 11:20 PM | #6 |
so with an ECE drop do you need the oversized ball joints?
11-06-2010, 11:30 PM | #7 |
67-72 parts collector,…
The 3/4 lower a-arm has a larger balljoint hole.
What are you working on? 1/2 ton or 3/4 ton? What year ECE spindles did you buy? Sounds like you got the wrong year balljoint with the incorrect taper. Lower ball joints should be either 67-70 or 71-87. Upper ball joints are 67-70, 71-72, or 73-87.
