Old 11-19-2007, 07:55 PM   #1
jaros44sr
jaros44sr's Avatar
Transfer case torque mount
OK, I'm an idiot... Dropped the t/c with out paying attention to how the torque mount goes back together. I looked in my assembley manual and the service manual, just one very small pic in it, not much help. Checked out the FAQ's no help. Seems like it's simple enuff, but it doesn't look right when I put it together.
Any pics. or help. pls....
Semper Fi...Uncle Sam, you da man
All parts offered to help are free, unless otherwise noted
Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training
SAFETY FIRST
AS usual, off topic
They say your mind goes second, can't remember the first
Jim
jaros44sr is offline   Reply With Quote
Old 11-19-2007, 09:04 PM   #2
1969k10stepside
Re: Transfer case torque mount
I can get you a pic tomorrow if no one else has by then.
1969k10stepside is offline   Reply With Quote
Old 11-19-2007, 09:39 PM   #3
jaros44sr
jaros44sr's Avatar
Thank you, no hurry. I can mount my crossmember back up without the torq mt. Maybe I should post up a pic. to show you the way I think it goes
SAFETY FIRST
AS usual, off topic
Jim
Old 11-19-2007, 10:21 PM   #4
Ace in the hole
you are talking about the side mount right, just did mine today, no pics but I'll try to explain the way mine went together. starting from the bottom- larger of the two halves of bushing, then a plate, then the main body of the bracket then the upper bushing and the center sleeve holds it all together. The plate mates right into the body, the curve of the holes match up. hope this is what your looking for, kind of hard to explain.
1970 K20, 350--- SOLD
05 silverado extended cab short box- duramax
Jeep wrangler unlimited
Ace in the hole is offline   Reply With Quote
Old 11-19-2007, 10:32 PM   #5
Ace in the hole
ran out and took a pic for you, I am still in the bare frame stage
Old 11-20-2007, 12:08 AM   #6
eedgell
It's the air up here
eedgell's Avatar
http://67-72chevytrucks.com/vboard/a...1&d=1195531633
NP 205. Hope this helps.
1971 cheyenne k10 4 speed np 205 454 BB factory a/c
Never drink down stream of the herd!
Eric
eedgell is offline   Reply With Quote
Old 11-20-2007, 08:09 AM   #7
jaros44sr
jaros44sr's Avatar
Thanks for the help guys, although I am still concerned. Seems wierd that they would have metal to metal on the oval pc. with the 2 holes in it.
Also the ID of the sleeve that goes in the urethane bushing is a little large compared to the original sleeve. Should I worry about this or make another sleeve to match the original specs.
I just rotated the oval plate 180 degrees, and the space between seems to match up better, in the pic you can see the gold anodize...
I would have put the thicker urethane pc. on top...anyway here are some pics.
SAFETY FIRST
AS usual, off topic
Jim
Old 11-20-2007, 09:38 AM   #8
71 super
71 super's Avatar
Who did you get your mounts through? I have to get mine soon and the only place that I have seen them was LMC.
71 super is offline   Reply With Quote
Old 11-20-2007, 09:49 AM   #9
jaros44sr
jaros44sr's Avatar
Trans. mounts bought at 4Xheaven, energy suspension #3.1106R. Great people to deal with. About $50.00
Torque Mount bought at Summit, Prothane 1603, Prothane doesn't carry trans. mounts, only '73 and up. Could be wrong on the part number, so check it out
Hope this helps. J.
SAFETY FIRST
AS usual, off topic
Jim
Old 11-20-2007, 11:23 AM   #10
Ace in the hole
That's not how mine went together. The plate fits into the other main bracket. kind of doubles up the metal so to speak. when the two are placed together they are right next to each other stacked together like if they were going to make a solid piece of steel rather than two separate pieces.
Old 11-20-2007, 11:40 AM   #11
jaros44sr
jaros44sr's Avatar
Ace, how's this look...
SAFETY FIRST
AS usual, off topic
Jim
Old 11-20-2007, 11:47 AM   #12
Ace in the hole
Ya, like that. I was trying to post a drawing for you-
Old 11-20-2007, 11:49 AM   #13
Ace in the hole
sorry, my drawing had the lips the bushing fits into going the wrong way.
Old 11-20-2007, 12:02 PM   #14
jaros44sr
jaros44sr's Avatar
Hey Ace, your drawing is way better than I could have
Thanks for the help, just finished mounting T/C back onto crossmember. Trying to get it back up into the truck...
My only concern now is the ID of the sleeve, I'll call Prothane tomorrow and see if they can help
Later J.
SAFETY FIRST
AS usual, off topic
Jim
Old 11-20-2007, 12:09 PM   #15
jaros44sr
jaros44sr's Avatar
Originally Posted by eedgell View Post
Dude, it looks like you broke a bolt on your torque mount, but thanks for the pics.
SAFETY FIRST
AS usual, off topic
Jim
Old 11-10-2011, 11:20 AM   #16
mlprater
Anybody have an idea of where I could buy the "thin plate" or oval piece?
Thanks,
Matt
mlprater is offline   Reply With Quote
Old 11-10-2011, 11:37 AM   #17
DirtyLarry
Windy Corner of a Dirty Street
DirtyLarry's Avatar
Everybody has an opinion but if it were me, I would take that transfercase side mount off and throw it in the trash, especially if you are pumping any respectable power out of the engine. Those side mounts are only good for breaking trans to tcase adapters and cracking bellhousings on automatic trans equipped rigs.
Recent thread on this same topic.
http://67-72chevytrucks.com/vboard/s...d.php?t=491001
DirtyLarry is offline   Reply With Quote
Old 11-11-2011, 11:33 PM   #18
jaros44sr
jaros44sr's Avatar
Thanks,
Matt
Sure, you can have mine, all painted up real pretty....dirty larry has a compelling arguement about using it
Larry, didnt the K case TH350 have rods from the flywheel cover up to the motor mounts
SAFETY FIRST
AS usual, off topic
Jim
Old 11-12-2011, 01:02 AM   #19
DirtyLarry
DirtyLarry's Avatar
I don’t recall those rods on TH350’s but 700R4’s in many years of pickups and G-vans had those rods from the torque converter dust shield up to the engine mount brackets.
Old 11-12-2011, 12:48 PM   #20
bmchevy1979
bmchevy1979's Avatar
Yes they do my Blazer has those rods
<Brandon>
1974 Chevrolet K5 Blazer 350sbc/SM465/NP205, dana44 front, corp 14bolt rear with 4.10s and a powertrax locker, custom rear bumper 400sbc in the works.
1981 GMC C1500 stepside 250i6, 3spd, 12bolt with 3.08s 2.5/4drop on 15x10 with 275/50r15
81 GMC C3500 cab-chassis dually with utility bed 350sbc, Sm465, 14bolt with 4.10s nv4500 getting ready to go in
1979 Chevrolet K5 R.I.P. http://67-72chevytrucks.com/vboard/s...d.php?t=434096
1976 Chevrolet C10 R.I.P. http://67-72chevytrucks.com/vboard/s...d.php?t=434195
bmchevy1979 is offline   Reply With Quote
Old 11-12-2011, 01:06 PM   #21
Redcap
Agreed. Even a stock 454 is too much for that T-case side mount.
Redcap is offline   Reply With Quote
Old 11-13-2011, 04:33 AM   #22
1malo68
1malo68's Avatar
Before you even reinstall it, you may want to check out this thread
http://67-72chevytrucks.com/vboard/s...62#post5005462
1968 K10/30
Frame Off Project "Overkill"
My 5 year, $30,000.00 toy
1malo68 is offline   Reply With Quote
Old 11-29-2015, 11:09 PM   #23
haskins10
hey guys. i have a 1979 k10 and i cant find this torque mount, side mount, strut brace its been called so many different names but i cant find it anywhere. im running a 205 with a th350 and that mount was not on the T case. i was driving down the road and the weight from the T case binded up the u-joint and snapped that off allowing all the weight from the T case to bounce around and it cracked my tranny housing. if anyone knows where to find this mount please send me a link or a general website. thanks
haskins10 is offline   Reply With Quote
Old 11-30-2015, 10:16 AM   #24
bmchevy1979
Some np205s are not drilled for the brace if you look at the passenger side of the case by theframe rail the will be a flat spot with two dimples or two threaded holes if its drilled and tapped my 205 is out of a 78 and isn't drilled so yours may not be either the np203 and 208 also had a arm that went from that point to a belllhousing bolt on auto trans trucks I'm not for sure if the 205 got the same treatment in an auto rig though
<Brandon>
Old 11-30-2015, 07:20 PM   #25
RedRoad
RedRoad's Avatar
I have a 78 3/4 ton 205 in my K5 and it does not have the boss drilled for the support brace.
RedRoad is offline   Reply With Quote
