11-19-2007, 08:35 PM | #1 |
Reciever hitch for a 72 blazer? anyone?
any ideas on where to get or buy a reciever hitch for my 72? I have been looking around and can only find hidden hitches that say they fit the trucks..I dont want a hidden hitch...any ideas? thanks![IMG]
11-19-2007, 08:37 PM | #2 |
I'm a poor spectator
Re: Reciever hitch for a 72 blazer? anyone?
They had some dealer installed ones around but good luck finding one, you're better off making one.
2006 Jeep Unlimited IMPACT ORANGE 1993 Chevy 2500 4x4 ExCab LWB 454/NV4500 Tow rig 1977 Ford F100 2x4 LWB 1st truck I owned, still have it!!! 1979 Ford F150 4x4 SWB Built Ford Tough!!! 1971 Chevy Blazer 350 / SM465 / NP205 UNDER CONSTRUCTION Soon to have a LQ4 6.0!!! |
11-19-2007, 10:53 PM | #3 |
Junior Member
I've got a hidden hitch on mine (I saw you didn't want one) what they don't tell you in the ad is that you have to take the extra bracket that 4wd drives have that support the rear spring perch. I removed mine and then drilled the hitch, bored out a piece of screw stock the correct length and got a longer bolt to tie the whole assembly in. Turned out very clean.
1972 K/5 4x4, Radixed LS1 6.0, 428HP/445TQ, Lingenfelter GT2-3 cam, WCCH 90mm J-Tube, LS2 90mm TB, Stainless Works Headers, NV4500, 4.56 gears, Detroit Lockers, 14 bolt FF, Dana 60, 4 wheel disk Hydro Brakes, dual electric fans, Autometer guages, 4" lift, Zero Rates, Weld Evo Velocity XT8 wheels, 35x12.5x17 Super Swamper SSR's..... http://s72.photobucket.com/albums/i1...tos/?start=all |
11-19-2007, 10:55 PM | #4 |
Rods
hmm i have the stock one.. it even fits with the stock skid plate. its worth the hunt if you can get one
11-19-2007, 11:21 PM | #5 |
Billyjo and 70 suburban...can u take pics and post em here so I can see what they look like? thanks!
11-20-2007, 09:58 AM | #6 |
Stock Receiver Hitch? Not that I am aware of.
As noted, the '72 frames are different. I had a "universal" hitch installed on mine by a hitch shop in '89. The brackets are made and are 2 1/2" so that the 2" cross bar with the receiver on it it can slide on them. It allows for any width, then holes are drilled in the frame to mount it. He also welded an additional 1/2" by 1 1/2" brace from the side of the hitch brackets to the side of the frame. The easiest thing to do is get a step bumper and bolt a receiver to it. Or just deal with the Hidden Hitch. I have a '72 Burb receiver hitch, any idea if the frames are the same? I'll try and use it on the new-to-me wrecked '72 Jimmy I just picked up if they are!
11-20-2007, 07:02 PM | #7 | |
Not a bad nut after all..
Would it work with the factory gas tank skid plate? Would it still work with the shorter '69-'71 Blazer frame?
'05 Chevy 2500HD 4x4 '72 GMC LWB 4x2 driver '72 Chevy LWB 4x4 plow truck '71 Blazer 4x4 driver '70 GMC LWB trailer |
11-20-2007, 08:19 PM | #8 |
Future TOTM Winner
Jtrux, what is the one that you have?
72 Chevy CST K5 HIGHLANDER BLAZER Getting a 6.0,NV4500,NP205,14BFF (Currently laying all over the place in little pieces) 72 Chevy swb step-side "LS" 6.0 Here's a build thread of sorts 2002 HD2500 Crew Cab, 8.1L Allison 4x4 Daily Driver Check it out www.lsdyno.com Last edited by Critter; 11-20-2007 at 08:19 PM. |
11-20-2007, 08:59 PM | #9 |
Mine was made by a previous owner. It's coming off eventually so maybe someone will want it. I never plan on pulling anything so I don't need it.
11-21-2007, 10:39 AM | #10 |
Here's some pics of the one I pulled off my 1970 Blazer.
Hope they help, Rg
Roger '68 Short step - https://67-72chevytrucks.com/vboard/...d.php?t=849675 '69 ('70?) 2wd Blazer '70 GMC Jimmy 2wd '73 Firebird - https://67-72chevytrucks.com/vboard/...d.php?t=853203 |
11-21-2007, 11:01 AM | #11 |
I had a Hidden Hitch on my 72 C10. I never had a problem with it, and it's not really hidden, just more of a name. FWIW, the hitch is now on my '69 4X4, with no problems.
1969 K10 - V8, 465, 205, 12 bolt, D44 2002-current 1969 K20 - V8, 465, 221, Eaton, D44 2012-current Nothin' but drums on all 4 corners! past horses in the stable 72 C10-short step (97-02), 68 C10-long fleet (06-12) |
11-21-2007, 04:56 PM | #12 |
If you build it, it wil fit...
'72 K5, known as 'the Fox.' |
11-21-2007, 05:07 PM | #13 |
The LuvShack Garage
ECE makes one, not sure how it fits, or if it's a hidden unit or not hidden
Owner/Op: "TN Classic Transport Carriers" The Toy: "Square Vette" 72 Hybrid Blazer Toy Barn: "LuvShack" 40 x 60 x 20 Shop Big Piggy: "Goliath" 07 Kodiak C4500 Lil Piggy:"Maddy" 88 Silverado 3500 Hauler: "Feathers" 14 Aluma 8218T |
11-21-2007, 10:01 PM | #14 |
mr freeze, all I have to say is 'wow' thats a pretty intense rear bumper..ragged jim, thanks for the pix!
11-21-2007, 10:42 PM | #15 |
Roadtrip!
On my 70 1/2 ton, i used a reciever from a 73 blazer that fit quite nicely. The reciever is right below the lic. plate with a sport bumper.
67 gmc custom lwb dakota truck. Sold...And bought back 69 swb 4x4 project (in progress) 70 c-10 lwb texas truck 70 4x4/BB/bkts/posi/tach(retired) 70 swb (wifes) 70 jimmy camper 71 K-5 factory 2wd 71 cheyenne 4x4/tach/posi/ plow rig 71 Cheyenne20 BB, buckets, tach, tilt, 4 speed 72 jimmy CST wyoming rig 72 jimmy Colorado rig 72 lifted texas 4x4 3/4 ton burb 65 fury conv. 383/auto 65 chrysler 300 "L" 413 auto |
11-21-2007, 10:47 PM | #16 |
11-21-2007, 11:18 PM | #17 | ||
Junior Member
I don't think so, I didn't try to put mine back on yet. I think for it to work you would have to sandwich the skid plate between the hitch and the frame. Even if you did this I can't say, I do plan later trying to make mine work I can't answer that one, maybe someone else can.
11-22-2007, 12:58 AM | #18 |
SKINNY TIRES RULE!
I've got an old Valley receiver on mine. I'll see if I have any pictures on my work computer tomorrow.
bouncytruck 1972 K5 The Hauler 1994 K1500 Suburban The Daily2010 Kia Soul Wife's Ride2014 Fiat 500L |
11-22-2007, 06:05 PM | #19 |
2wd FTW!!!!
I Think Mine Is Home Made But It Works Well. It Takes Place Of The Center Bumper Brackets And It Looks Factory
11-23-2007, 10:10 AM | #20 |
I searched for a long time and ECE is the only company currently making one for 69-72 K5s. I put one on mine late last year but have yet to use it. Yes it is "hidden", almost completely concealed by the bumper and license plate.
-Chris Building a stripper, one part at a time: 1969 K5, 307, 3spd, 3 seats, hard top. Added Pwr Discs, Pwr Steering, Aux Battery, T-case Skid, Lighted Sidemarkers, HEI, Lock-Right Diff, ECE Class IV Hitch, 32" MT/Rs. Parts to Install: Hand Throttle, Console, Tow Hooks, Dual Horns, AM-FM, Dealer Swing-Away Tire Carrier, Gas Tank Skid. Also building a 1950 Willys CJ-3A and off-roading a 2001 Nissan Frontier on 1-Ton Portals... |
11-23-2007, 11:59 AM | #21 |
Rods
nice If it will clear the skid plate im game for one of these
11-23-2007, 12:53 PM | #22 |
Mine looks very similar and mounts just like raggedjim's and is sitting on the floor of my garage. PM me if you're interested in it. I don't intend to put it back on. It was on the truck when I got it. Cleared the gas tank skidplate with no issues.
11-23-2007, 01:15 PM | #23 | |
Towrig, Do you have any pics of your exhaust? I like the way it exits. I don't know how it bends around the gas tank
Semper Fi...Uncle Sam, you da man All parts offered to help are free, unless otherwise noted Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training SAFETY FIRST AS usual, off topic They say your mind goes second, can't remember the first Jim |
11-23-2007, 01:52 PM | #24 |
jaros, it is the aluminized system from LMC. I will send you a PM with additional info.
02-28-2008, 09:52 PM | #25 |
I had one made by U-HAUL custom.If you need I'll send picture. I did talk to two different U-Haul. Found part #UHI75914 COST $149.95
