Old 11-19-2007, 08:46 PM   #1
70C10Step
70C10Step's Avatar
87 350 Engine????
Okay the valve covers bolt down through the center. What type of carb intake does this application use to drop in my 70 stepside? Engine is coming out of a 1987 C20 Van... This is my first chevy truck build. Educate me please! Thanks in advance!!!
All Toys:
1971 C10 Fleetside - I needed it!
1970 C10 Stepside - Midlife Crisis
1969 C20 3/4 Longbed - Beast!
1966 Mustang Fastback - Daily Fun
1965 Mustang Fastback - Money pit!
70C10Step is offline   Reply With Quote
Old 11-19-2007, 09:34 PM   #2
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
Re: 87 350 Engine????
You can use any normal small block intake on those heads. You'll need to slightly enlongate the center two bolt holes on each side. Other than that, the later heads don't cause any fitment problems.
If you search, this was covered in some depth in the past. I posted pictures of an intake or two that I did this to. Copy the pictures and you're good to go.
