Is there a shorter Master Cylinder that bolts-right-up?
Just looking for something that works and doesnt stick out so far and easy to install. 71'blazer
Blazer Project Last edited by gottwake; 11-20-2007 at 12:42 AM. |
Re: Is there a shorter Master Cylinder that bolts-right-up?
my master cylinder on my 72 chevy just went out...i go to autozone and buy a rebuilt one for $14....and it took about 20 minutes to put it in and bleed it
I have to get one installed, How do you bench bleed to get air out?
Not to hijack. I dont think you can get much shorter MC. Ron
Member #111 68 C-10 ![]() 70 ![]() 76 Jeep CJ-5 Help Support the Board: http://67-72chevytrucks.com/vboard/payments.php He who knows nothing is closer to the truth than he whose mind is filled with falsehoods and errors. Thomas Jefferson |
want it shorter to look more streamline / custom.
Blazer Project |
They make smaller Boosters.
Ron
#6 | |
Put it in a vise, or a holding fixture so you can have both you hands free....fill the reservoir, using the supplied fittings a tubing that comes with your new cylinder. screw in the fitting, attach the hoses and route them back up into the reservoir. Using a screw driver or something else that is long. Pump the mastercylinder until all the air is out...or until you dont hear the "sloshing" noise anymore.
