Old 11-20-2007, 04:31 AM   #1
mateo1279
mateo1279's Avatar
Starting issue!
Here's the deal-
I have had this issue come up a few times:
I start my truck and drive it, say, to the store. I come out to start it. Turn the key and... nothing. No click. Engine doesn't turn. Nothing. I then proceed to get pissed. Then wait . Then try again... Then as I am thinking I need a tow I try again, a few hours later and wal-la, it starts right up. This has happened about 4 times in the last year. The one variable that stands out is when this happens I have a load in the back, though not very heavy. It must be related to the electrical/starting system, I just can't figure out where. It can't be the battry charge. It can't be the alternator. I don't see how it could be the physical wires... could it be the starter? I am stumped!
Thanks for the help!
-Matt
1962 Chevy Fleetside
283/TH350
mateo1279 is offline   Reply With Quote
Old 11-20-2007, 04:47 AM   #2
Bishops Trucks
KEEP ON TRUCKIN'
Bishops Trucks's Avatar
Re: Starting issue!
Sounds like the starter is getting the dreaded heatsoak problem. Buy a new starter and get a starter heat wrap from http://store.summitracing.com/egnsea...68&D=%2D118668 and install them. You should have no problems after that.
JIM
'97 GMC Sierra K1500
'95 Chevy Silverado C1500
'71 Cheyenne Z71 / LT1 & 4-Speed SWB K/10 Father/Son Project
http://www.youtube.com/watch?v=4l689JKXPnA
"LIVIN' FREE FOREVER"
Bishops Trucks is offline   Reply With Quote
Old 11-20-2007, 05:06 AM   #3
Iron-Butt
454 club
Iron-Butt's Avatar
Re: Starting issue!
I replaced my starter and it fixed the same problem
David
1965 Chevrolet c-10 454 automatic Custom bbw swb.
1965 Chevrolet C-10 swb (Sold)
1963 Chevrolet C-10 6 Cyl automatic with dual exhaust, pb, ps and 17's.
R.I.P "I will miss you.
1967 Chevrolet C-10 6 Cyl Custom lwb
1939 Chevrolet Coupe, 350 v8 automatic.
1935 Chevrolet 2 Dr Standard in the works.
2015 Harley Davidson Street Glide.
2023 Chevrolet Stingray Z51 Convertible.
I never want to grow up.
Iron-Butt is offline   Reply With Quote
Old 11-20-2007, 07:00 AM   #4
rodnok1
rodnok1's Avatar
Re: Starting issue!
It can be wire related also, the wires get weak after being heated up time after time and current just won't go through. Most wires of this age need replaced going to starter/oil doesn't help them any either. A quick/cheap thing to try is to replcae the wires...I always change the batt cable to a zero gauge also...I hate starting problems.
64 Panel Rebuild Pics
Clutch Replacement and Borg Warner T10 Trans Rebuild
64 Panel 1/2 Ton
350cubes/400hp
BorgWarner t-10
3:73 Auburn Posi
rodnok1 is offline   Reply With Quote
