th400 kickdown detent switch
What is the proper operation of the th400 kickdown detent switch mounted on the gas pedal ('72)? Mine does not move freely. I assume the gas pedal rod is supposed to push the switch to kickdown the tranny at high throttle? I can manually move the switch, but it will stick in that position.
If that's not correct, is it possible to clean it up? thx, eric
72 C2500 LWB 402 Sierra Grande 05 Odyssey 08 Tundra |
Re: th400 kickdown detent switch
The switch should slid freely. There is a spring in it to push it back. Never tried cleaning but some crc 226 or electric contact cleaner should clean the switch.
72 longhorn c30 502BB/th400/fact air/4.11rear/ custom camper 72 bug(the better half's) under reconstruction 2009 HHR aqua blue 71 GMC k20 350/sm465 2009 Chevy hd3500 6.6 Victory Red crew cab dually Dave & Jeanne |
its all about the +6 inches
it is avalible at the parts store, and I wouldn't be surprised if the dealer still had it too. They used it into the 90's on TH400 equipped P/30 trucks.
![]() Join Date: Jul 2003
Part number 1242101 is still available thru GM. List price is $23.70.
1970 K/5 Blazer CST 4WD, Bronze, 93k ACT. miles, 350, 4 speed, positraction, 16.5" x 8.25" wheel option, tilt, tach, vacuum, AM/FM, manual throttle...Dad ordered and purchased new 4/70. Currently frame off restoration in progress... ![]() 1972 Cheyenne Super 20 2WD, DK Blue/White, 90K ACT. miles, 402, TH400, 4.10 open, tilt, tach, vacuum, A/C, AM/FM, manual throttle.. A mostly original paint never rusted Texas survivor... ![]() 2017 Sierra 1500 SLT 4WD, Black, 41k miles, 5.3, 6L80E, 3.42 LS, 20" polished wheels, everything but moonroof and 6.2... 2019 Canyon SLT 4WD, White, 60k miles, 3.6, 8L45, 3.23 LS, 18" wheels |
Thanks for the replies. I'll see about replacing it.
I finally got around to replacing the throttle cable on my truck, and it's too long by about 1.5".
