Old 11-20-2007, 07:21 AM   #1
w314speed
TH400 into 72 K20 CHANGES/PROBLEMS
I am planning a swap from TH350 to TH400.... What will I need to expect using the stock NP205.
w314speed is offline   Reply With Quote
Old 11-20-2007, 08:23 PM   #2
cobinder
Everything is work in progress
cobinder's Avatar
Re: TH400 into 72 K20 CHANGES/PROBLEMS
Depends on what 205 you have. If it's the old style (figure 8 bolt pattern)Your gonna need the mounting adapter made for the 400 (ebay $100) and your going to have to replace the input shaft on your 205 with one that has 32 spline female. Advance might make an adapter for the 4 different old style 205 input shafts.
Good luck with your truck!
How much?! It's just an old truck part!!
49 International on a 80 GMC 3/4ton 4x4 chassis
48 International KB-5 2 ton dump bed
04 Honda CRF "500"
09 Honda CRF450 fuel injected rocket
03 Suzuki hayabusa carbonfiber wheeled monster.
02 Ford diesel stretch van (toy hauler)
01 38' Monaco diesel pusher motorhome
cobinder is offline   Reply With Quote
Old 11-20-2007, 08:34 PM   #3
w314speed
I have the old style 205- figure 8 pattern and I have the adapter. I would need the 32 spline conversion done! Will the trans cross member and TC mount need to be relocated??
Thanks for all you input!!!
Old 11-20-2007, 09:07 PM   #4
jeffspower
Well, Whoop-dee-do!
jeffspower's Avatar
Done it on my '72 K20. Crossmember will need to be moved further back, shorten rear shaft, lengthen front. You might have to modify the shifter a bit to come thru the floor properly, as it sits further back too.
'68 GMC shortbox 4x4 350/SM465/T221- bought it in '83 SOLD
'72 K20 500 Cad/TH400/NP205 SOLD
'92 Chevy 2500 6.5 mech TD 4L80E crusty daily driver
'72 Monte Carlo... sweet low mile toy
'11 Dodge Challenger IE 392 6spd... midlife car
jeffspower is offline   Reply With Quote
