Old 11-20-2007, 08:00 AM   #1
nac593
Aftermarket power steering help ques.?
I bought a Brothers power steering kit. It says altenator has to be on the left side. Is that Drivers or pass? My altenator is on the pass side. Will it work?
No A/C, long water pump, 350 sb. I dont want to switch my altenator to the other side because I dont have different brackets. Thanks for any help.
nac593 is offline   Reply With Quote
Old 11-20-2007, 08:36 AM   #2
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
Re: Aftermarket power steering help ques.?
Alternator on the left side means driver's side. Your long water pump and passenger (right) side mounted alternator are not original.
You'd need more than brackets to do the swap to original left side alternator. You'd need three pulleys, belt, fan spacer, and a water pump and bolts.
It it were me, I'd return the stuff to Brothers and go to a junkyard and get a pump and brackets off any 73-87 model truck. They came with long water pumps and right side mounted alternators stock, so it will be cheaper and easier to go that route.
Just get the pump with brackets, hoses, steering box, and pitman arm. Once you have those items, it's a 2 hour job no sweat.
Old 11-20-2007, 09:08 AM   #3
nac593
Thanks for the advice. Will the setup from a 1 ton work?
Old 11-20-2007, 12:16 PM   #4
PanelDeland
I am a Referee of life.
PanelDeland's Avatar
Just for future reference all left/right stuff is supposed to be as from the drivers seat.Note I said supposed to be.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion.
You can't fix stupid,not even with duct tape.
"My appearance is due to the fact that "GOD" does punish you for having too much fun!"
Barrett-Jackson has perfected alchemy,they make rust into gold!
"You can lead a horse to water but you can't saddle a duck"
"Cleverly disguised as a 'Responsible Adult'
"Sometimes your Knight in shining armor is just a retard in tinfoil"
PanelDeland is offline   Reply With Quote
