Old 11-20-2007, 12:18 PM   #1
rick0312
rick0312's Avatar
Steering stablilizer
I am currently redoing the front end of my 69 1/2 ton and was wondering if any of you guys have installed a steering stabilizer? Do they improve the steering? Any pics of the setup would be helpfull...thanks....rick
rick0312 is offline   Reply With Quote
Old 11-20-2007, 12:53 PM   #2
Sweet72
Sweet72's Avatar
Re: Steering stablilizer
Is your truck driving like a tractor in high gear going across a field full of badger holes? I've seen the stabilizers on 4 wheel drive trucks, but not on 2wd. Do you have power steering?
'72 GMC SWB C1500 Custom, frame-off in progress. 383 SBC, 9:1CR, Comp Cams XE262H, Scat internal balanced crank, Eagle SIR 6" rods, Keith Black dish pistons, Dart Iron Eagle 72/180 heads, Weiand Stealth intake, Stewart stage I water pump, Holley 4bbl vac sec, TH350 with B&M Shift Improver Kit. 12 bolt positraction.
Sweet72 is offline   Reply With Quote
Old 11-20-2007, 01:02 PM   #3
rick0312
rick0312's Avatar
I have power sterring and it drives ok, sounds like i don't need a stabilizer.
Old 11-20-2007, 01:09 PM   #4
Sweet72
Sweet72's Avatar
My GMC was a beast to drive with manual steering and brakes, the 16 inch stock wheels and bias ply tires and I considered a stabilizer, but when I went to 15's and converted to power all was good.
Old 11-20-2007, 01:23 PM   #5
Mordachai
Fat Fendered Fleetside
Mordachai's Avatar
I had put one in my truck before I switched it to Power steering. My truck is 2wd, but after bumping a curb and having the wheel spin so fast that it nearly took off my hand, was time to put a stabilizer in. When I put the PS unit in it I took the stabilizer out, for no real reason other than to clean up the front...
But I don't know why you would really want on in a 2wd. it shouldn't affect the steering, if your ball joints and pitman/idler arm are bent or worn out, then even with a stabilizer you'll still have sloppy steering....
71 GMC lwb
56 Big window swb
93 GMC Sonoma (dd)
radiused fiberglass fender project for 67-72
Mordachai is offline   Reply With Quote
