Old 10-09-2002, 02:49 PM   #1
HotRod929
HotRod929's Avatar
Location: Bondurant, IA but in Worcester, MA for school
Alternator Question???
Did all the 73 and up trucks come with a one wire alternator? Just wondering cus im thinking of getting a new one but it doesnt say one wire or not just 73 and up. Thanks
HotRod
1970 Chevy C-20
350 V-8
Turbo 350 w/ shift kit
Dana 60 w/ 4.10 gears AND Powr-Loc POSI
New Additions:
Summit Headers
135amp alternator
Proform HEI
Edelbrock 1406 600cfm carb
Sunpro Tach
Powr-Loc POSI
Edelbrock Performer RPM Intake
MSD 6A Ignition Box
AIM: HotRod929
Visit My Site: http://1970chevy.netfirms.com/
HotRod929 is offline   Reply With Quote
Old 10-09-2002, 06:05 PM   #2
HotRod929
HotRod929's Avatar
Someone?...Anyone?....Someone out there has got to know. Please Thanks
HotRod
1970 Chevy C-20
350 V-8
New Additions:
Summit Headers
135amp alternator
Proform HEI
Sunpro Tach
Powr-Loc POSI
MSD 6A Ignition Box
AIM: HotRod929
Old 10-09-2002, 06:08 PM   #3
Mike C
Mike C's Avatar
GM has never sold a truck with a one wire alternator. They do, however, have an internal regulator from 73. It is possible to jumper the plug in the side and make it a one wire hookup, and this is basically what an aftermarket one wire does, it just runs all the wires inside the case.
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
Old 10-09-2002, 06:12 PM   #4
HotRod929
HotRod929's Avatar
So jumper the two spade terminals on the alternator and I got a one wire? If thats the case is there any where I can get a jumper plug for it? THanks
HotROd
1970 Chevy C-20
350 V-8
New Additions:
Summit Headers
135amp alternator
Proform HEI
Sunpro Tach
Powr-Loc POSI
MSD 6A Ignition Box
AIM: HotRod929
Old 10-09-2002, 10:33 PM   #5
mikep
Used to have a truck
mikep's Avatar
There is a different diode set in the one wire alternators than in the newer ( post 72 ) internally regulated alternators. Jumpering the other two wires wont do it alone.
No truck :-(
mikep is offline   Reply With Quote
Old 10-09-2002, 10:35 PM   #6
Mike C
Mike C's Avatar
It works on an internal regulator allternator, not the original one on your truck. I'm not sure which way to jump what for sure. I did this on our Poppin' Johnny years ago, but don't rememeber. do a search for the Oldsmobile FAQ on alternator conversion to internal regulator. That is the best post I have ever seen on the subject. I think you can buy a pigtail at the parts store that lets you just plug it in.
44 Willys MB
52 M38A1
64 Corvette Coupe
Old 10-10-2002, 01:47 AM   #7
Slammed67
Progress = 0%
Slammed67's Avatar
Correct me if I'm wrong, but I don't think just hooking the two wires together makes it a one wire alternator. You can but conversion kits for them though. If you hook the two wires together, then the alternator is always "charged". I tried this thinking it would work and it drained my battery. The small wire is what "activates" the alternator, so it needs to be hooked up to12v controlled by the ignition. That way it's only on when the ignition is on.
Jason - '67 GMC swb | '57 Bel-Air 4dr hardtop | '56 210 4dr Wagon | 2000 GMC Sierra
Slammed67 is offline   Reply With Quote
Old 10-10-2002, 08:17 AM   #8
Mike C
Mike C's Avatar
Correct, just jumping the two wires won't do it. But buying the pigtail at the parts store that jumpers the 12v post to one of the pins and uses a diode on the other (I don't remember the exact order) DOES work. Our John Deere's has been on for 10 years now. It's also just as easy to hook it up via the instructions on the Oldsmobile FAQ when replacing the externally regulated alternator.
44 Willys MB
52 M38A1
64 Corvette Coupe
Old 10-10-2002, 08:56 AM   #9
mikep
mikep's Avatar
www.alterstart.com has rebuilt 105 amp one wire alternators internally converted to one wire for $55. Hard to beat that.
I always have to push this too. They have NEW in the box AC delco permanent magnet gear reduction starters like chevy supplies with their 502 big block kits for only $99 which is half what the parts stores charge for rebuilt ones.
No truck :-(
Old 10-10-2002, 09:25 AM   #10
Alaskan
Truck'n the alcan
Alaskan's Avatar
Use this link, http://home.gci.net/~rflory/alternator.html it discribes how to hookup (wire) standard internally regulated alternator in place of the externally regulated alternator.
You can also wire it with the old wires you just need a new style connector. Example of new style connector [ -- -- ], example of old style connector [ | | ]. If you use the old wiring you also need to jump the wires where it plugs into old regulator, I'll need some help here from the board but it should jump 1 to 3, and 2 to 4.
A true one alternator will not produce current untill about 1500 rpm.
68 GMC 4x4
71 C20 Custom Deluxe
83 1/2 ton conversion van
Alaskan is offline   Reply With Quote
Old 10-10-2002, 11:45 AM   #11
mikep
mikep's Avatar
I will have to add that that 1500 rpm can be a bit of a pain sometimes. I run a deep groove moroso 4 inch pulley to for better belt retention with a green industrial belt and that 1500 rpm is more like 2300 rpm. I can ee when I hit 30 mph in 2nd gear when it come on. The lights suddenly get brighter. It doesnt really bother me since I like the extra secuity of the deep groove pulley. Lost an engine one because of a thrown belt so I'm over cautious.
No truck :-(
Old 10-11-2002, 12:44 AM   #12
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Personally, I don't see the atraction on these one wire deals. With all the wires that are there already, what does it matter if you have a couple more that should be neatly tied and wrapped?
The cost and the 1500 rpm(depending on pully size) rev to get it to turn on seem like a couple good reasons to just get a GM int reg unit and install it.
You can maintain your dummy light/guage like this too.
Old 10-11-2002, 01:10 AM   #13
mikep
mikep's Avatar
You can maintain the gauge with the one wire alternator too just as easily if not more so than a standard internally regulated alternator . The problem lies in the amperage rating of the alternator. It can produce upwards of 135 amps on demand depending on the model but so can some models of internally regulated alternators. It is not safe to run either a hi amp internally regulated or a one wire alternator through the original wiring which is sized for 35 amperes max . If you run the hi amp internally regulated alternator through a fusible link or a fuse then it is safe to do so but that eliminates the advantage of the extra charging capabilities a lot of modern extras like campers, inverters, stupid loud stereos, halogen lights etc need.
No truck :-(
Old 10-11-2002, 01:14 AM   #14
O'l Buck
Recovering Truck Driver
O'l Buck's Avatar
all of the one's i've converted, I bought a new aftermarket connector for the regulater, just a standard factory style connector....but new.....and hooked the red wire to the battery terminal on the alt. left the white wire open, and ran battery voltage to the bat. terminal........they all work just fine.
67 K-20 350, SM465, Eaton rear, 4.56 no spin option
00 Dodge 2500 4x4, 24V cummins, 5 speed
Chad
South Central Nebraska
O'l Buck is offline   Reply With Quote
Old 10-11-2002, 10:36 PM   #15
puffsburb
Just go to your local NAPA and get part # 13-4011sw. It is a one wire alternater NO modifications.
puffsburb is offline   Reply With Quote
