Old 11-20-2007, 06:14 PM   #1
dave3156
WTB HEI Distributor
I had my timing chain on my 1970 350 slip two gears and the shaft break on my HEI distributor. I just got done replacing the timing chain (went with Comp Cam double roller), timing chain cover, oil pan gasket (had to drop oil pan to pull timing cover) and motor mounts. The HEI distributor that broke was only about 3 months old with a 65,000 volt supercoil. It was one that other board members had used with good luck, but its toast. I need to replace it. Anybody have anything laying around that will work for me. All the electronics on what I have are new, just the shaft is broken. (The top and bottom are no longer connected, even though it still looks the same) Any help appreciated. Thanks.
dave3156 is offline   Reply With Quote
Old 11-20-2007, 07:39 PM   #2
billsbowtie
billsbowtie's Avatar
Re: WTB HEI Distributor
i have one if i can find it. $20.00 and $10.00 shipping.
i have 67/72 chevy truck parts f/s.
billsbowtie is offline   Reply With Quote
Old 11-20-2007, 09:27 PM   #3
dave3156
Let me know if you come up with it. Thanks
Old 11-21-2007, 09:22 AM   #4
dave3156
Bill, I asked around here and found one. Thanks for looking, if you came up with it I'm sure someone else here needs it. Thanks again.
Old 11-21-2007, 06:29 PM   #5
billsbowtie
i found it if anyone else needs one.[SOLD]
Old 11-21-2007, 07:00 PM   #6
BCOWANWHEELS
bill bring the hei dist to me when you come monday.
bob
I BELIEVE IN JOHN 3:16
BCOWANWHEELS is offline   Reply With Quote
