Old 11-20-2007, 07:32 PM   #1
grady5
early '90s 454 and turbo 400
i posted this in the engine forum but didnt get much help so ill try here. i found a 454 and turbo 400 in a early '90s dually. i can get the motor,trans, radiator'and all the accesories for $800. it runs good and no smoke. my question is what kind of power will this give me? i know it wont have the power of the older 454's but will it be a fun to drive motor in a weekend street truck? i would probably put a small cam in it just for sound other than that i dont want to spend a lot of money on it. thanks for any help.
grady5 is offline   Reply With Quote
Old 11-20-2007, 07:43 PM   #2
1970cstblazer
1970cstblazer's Avatar
Exclamation Re: early '90s 454 and turbo 400
The factory rated the 454 in the early 90's with 230hp and 385 ft/lbs of torque. The CR, cam and heads are limiting the HP on those engines.
1970 K/5 Blazer CST 4WD, TOTM winner December 2024! Medium Bronze poly, 93k ACT. miles, 350, 4 speed, rear positraction, 16.5" x 8.25" HD Kelsey Hayes wheel option, tilt, tach, vacuum, AM/FM, manual throttle...Dad ordered and purchased new 4/70. Currently frame off restoration finally getting close to completion..
2017 Sierra 1500 SLT 4WD, Black, 46k miles, 5.3, 6L80E, 3.42 LS, 20" polished wheels, everything but moonroof and 6.2...
2019 Canyon SLT 4WD, White, 67k miles, 3.6, 8L45, 3.23 LS, 18" wheels
Old 11-20-2007, 08:08 PM   #3
grady5
would this be a good motor to start with? torque is what really matters right? thats not a bad torque number for that low horsepower.
Old 11-20-2007, 09:19 PM   #4
WorkinLonghorn
WorkinLonghorn's Avatar
That's down low torque. I remember the early 90's and people were quite pleased with the 454 fi power.
'69 GMC C2500 Custom Camper, 8 1/2' bed, New GM 350, NP 435 Close Ratio 4spd. Trans., 3.73 Dana-60 open.Camper and Trailer wiring, PS, PB, AC, tach , three gas tanks, stereo speakers, 2nd owner, Work-Truck supreme.
WorkinLonghorn is offline   Reply With Quote
Old 11-20-2007, 09:27 PM   #5
grady5
the fi has been replaced with an edlebrock alum. intake and a duel line holley.
Old 11-20-2007, 10:09 PM   #6
clay68c10
clay68c10's Avatar
I'd guess that 454 would have the peanut port heads. Not great for rpm, but low end torque is ok. You could always change heads later if you want.
For $800 with trans & extras, I'd get it.
ClusterTruck: 68 C10 Bought in 89, wrecked in 03. Slow low $ rebuild started '17. 6.0 & TKO
http://67-72chevytrucks.com/vboard/s...d.php?t=788602
93 K1500 Short Step, 350, NV4500, EBL flash ECU. Vortec heads & roller cam someday...
05 Jeep Wrangler Unlimited. 3” lift & 6-speed
02 E320 the insurance total “free car”
13 Tahoe LTZ
clay68c10 is offline   Reply With Quote
