Old 10-09-2002, 03:18 PM   #1
72ChevyCheyenne
72ChevyCheyenne's Avatar
Fuel Injection Question
How do you set up the return fuel line on a fuel injected engine? I am planning on installing a 502 Ram Jet with a Blazer tank in the back. I want to mount the electric fuel pump close to the tank. Does the return line come off the injector or the pump?
Bill Durham
http://home.attbi.com/~bulldurham
72 Cheyenne
Restoration in progress
Currently: frame sand blasted and powdercoated, Inline Tube brake and fuel lines, Blazer tank in rear, Holley Red electronic fuel pump, Eaton posi with 3.42 gears, 2 1/2" drop front spindles, 4" drop rear springs with adjustable panhard bar, KYB shocks, ZZ 502/502 GM Performance crate engine, Zoops brackets and pulleys, Vintage Air, dual electric fans, Ram Air II hood and late model sport side bed.
72ChevyCheyenne is offline   Reply With Quote
Old 10-09-2002, 03:42 PM   #2
jmil1974
Ain't we cute?
jmil1974's Avatar
Most (all I have seen) return lines come off the fuel rail and back to the tank via a separate line (should be same size or LARGER than the supply line). If there's no bung for a return line on the tank, Moroso makes a return line kit for the filler hose that I hear works pretty well. Make sure to use an internal pump or at least get the external pump lower than the tank sump to avoid early pump death or vapor lock. Internal are best for siphoning reasons as well as lubrication and cooling reasons. I know some off-road guys who wire in 2 external pumps with a switch in case they have a failure they can flip a switch and drive home. Use hard lines if possible though stronger EFI-rated rubber lines are now readily available at most parts stores.
69 C10 2WD LWB Fleet 350/350 power front disc conversion (6 lug disc kit from gmcpauls) and new engine, PS, A/C, fresh fluids, SHE DRIVES!
FOR SALE $3900
jmil1974 is offline   Reply With Quote
