Serpentine Setup Help????
Okay I have searched for a setup to work with my swap. I am putting a 87 TBI engine in my 70 stepside. The motor will have a carb. I want to keep the serpentine setup but I am only running a alternator, waterpump, power steering and crank pulley... Anyone got a setup they can post??? I am trying to avoid spending big bucks on March setup....
All Toys: 1971 C10 Fleetside - I needed it! 1970 C10 Stepside - Midlife Crisis 1969 C20 3/4 Longbed - Beast! 1966 Mustang Fastback - Daily Fun 1965 Mustang Fastback - Money pit! |
Re: Serpentine Setup Help????
Try hotrodlane.com. That is Street and Performance. They have everything.
Kerry
1969 Chevelle 1990 IROC Z Convertible 2002 Silverado LT |
Watch out for your cornhole !
![]() Join Date: Jun 2003
I'm sure the GM parts counter would be happy to set you up with what you need to make your current parts work. All you need is to copy an 88-95 truck with no A/C. Somtimes they sell idler pulleys to take the place of the A/C compressor and smog pump on low option trucks.
Active Member
Summit has a GM kit either with or without A/C. You may have to call them. They sell them with their crate engines.
Sonny New Project: 67 Small window SWB 2006 Crew Cab Silverado LT ![]() ![]() |
![]() ![]() Join Date: Jul 2002
Mine came off a 94 C1500 model truck (with 4.3). I picked up the power steering pump and AC compressor with it. I bought a AC Delete from the dealer to run until I decided to hook up the Vintage Air system. Oh yeah, you'll need a reverse water pump. Also on the power steering pump, I changed the fitting end by taking the fitting off the back of an older (72) pump and put it on the newer stsyle so I could use the original power steering lines.
check your pm, and you can find the ac delete pulley from gm or ebay.
1986 C10 SWB 6.0/6l90e Miami...Flee it like a native |
instagram "footbraker67"
Why not try a Vortec setup?
I'm a poor spectator
How much would a serpentine setup typically cost from a junk yard?
2006 Jeep Unlimited IMPACT ORANGE 1993 Chevy 2500 4x4 ExCab LWB 454/NV4500 Tow rig ![]() 1977 Ford F100 2x4 LWB 1st truck I owned, still have it!!! ![]() 1979 Ford F150 4x4 SWB Built Ford Tough!!! ![]() 1971 Chevy Blazer 350 / SM465 / NP205 UNDER CONSTRUCTION Soon to have a LQ4 6.0!!! |
I have a serpentine setup on the engine I am putting in the truck. I am going to look for a ac delete bracket and I should be fine.
Someone on here a while back said look in junk yards for "White Astro Vans". They all came with 4.3 and non a/c serps.. I think cause they were mostly for companys.
1997 GMC Sierra Ext 1965 Mustang Last edited by 70GMCer; 11-21-2007 at 07:05 AM. |
blood type; Retumbo
Dorman (available from most any parts store) sells the AC delete pulley thing.
www.dormanproducts.com |
Thanks!!! I will be trying to track one down today!!!
#13 |
That was me. Look for 1 ton or 3/4 ton vans used by contractors & plumbers. The one I found was a 1995 and it had a 5.7 with no AC and no Smog pump. The only problem is the yards don't want to part motors since they try to sell them whole.
#14 |
87 tbi motor were in the square body trucks - 81-87 - the set-up works without A/C - it is a std. three belt arrangement using a thick 1" belt for the alt water and crank and smaller for A/C and PS. i used this system and it worked great with a carb setup - this is similiar to late 80's camaro's - i have no leads on a serp setup that wont break the bank though
#15 |
More Cowbell....
Got my setup from the junkyard, too. I gave almost $30 for mine. Then a few more to Wes (I believe) for the A/C delete.
There once was a member from Puckett.....Who ( fill in the blank blank blank ) bucket |
#16 |
blood type; Retumbo
I have the same set-up as Putter waiting its turn at my truck. it came from an 89 Caprice 305. it came with all the accessories as well. total cost? free!! a customer burned his 30K mile goodwrench 350 due to not having the EGR connected properly, he brought in this used 305 and all he wanted was his truck running again. hehehe
#17 |
I went to Kragen auto parts and ordered the ac delete pulley and bracket for $26.00. I will pick it up at lunch today. Thanks for the input...
