Old 11-20-2007, 11:00 PM   #1
metalman427
Late model suspension swap
You guys have probably been ask this one before. Is there any advantage to swapping the front crossmember on my '67 with a later Chevy front crossmember? I have a complete setup out of a '90 Suburban. I'm doing a frame off, but like a lot of people, watching pennies.
metalman427 is offline   Reply With Quote
Old 11-20-2007, 11:30 PM   #2
dave2953
Dave's not here, man
dave2953's Avatar
Re: Late model suspension swap
There are a lot of pluses for doing the swap. Obviously you'll have the disk brakes, plus the front end parts for the later trucks are a lot cheaper. I did my swap from an '89 Suburban and I love it. I've also heard guys say that they prefer the new control arm bushings that are all rubber as opposed to the old type that have the metal in them. The only real downside I've found is that I couldn't use my 6 lug rallys. BTW, to the board!
- 2014 VW Jetta
- 2015 VW Jetta
- 1966 Ford F-250
dave2953 is offline   Reply With Quote
Old 11-21-2007, 10:16 PM   #3
metalman427
Is there anything special about the sway that I need to know, or is it just a simple swap?
Old 11-22-2007, 12:48 AM   #4
dave2953
dave2953's Avatar
The sway bar will bolt up. However, if your truck didn't have one factory I think there are a couple of rivets that need to be removed in order to install the sway bar brackets. Also, if your truck is lowered or if you plan on lowering I would recommend getting a set of lowered sway bar brackets. I got mine from Early Classic. They were inexpensive and fit beautifully. Here is a link to the FAQ thread that TxFirefighter wrote about the install. It's what I used when I installed mine. Hope this helps.
http://67-72chevytrucks.com/vboard/s...ad.php?t=72338
- 2014 VW Jetta
- 2015 VW Jetta
- 1966 Ford F-250
Old 11-22-2007, 09:59 PM   #5
metalman427
Thanks man, I owe you one.
