11-21-2007, 12:49 PM | #1 |
Big Block Motor Mounts
I was wonder is there a differents in motor mounts for a big block 67-68 vs 69-72? Any pictures?
Thanks Drew
DREW67 |
11-21-2007, 12:58 PM | #2 |
Project Junkie! Fishing Poor!!
Re: Big Block Motor Mounts
67s didn't have big blocks, 68-71 has one style of mount and 72 has another. Pictures are on my other computer or I would post them. WES
On-line catolog Classic Heartbeat Pickup Parts WEHEPP@comcast.net Call us Toll Free (888) 338-2502 Like Us on Facebook No appointment necessary. 72 BB Chevy Custom Deluxe / Custom Camper 67 I-6 (Soon to be 5.7 LS1) Panel 68 BB Chevy Short Bed 72 6.0 LQ9 Short Bed Chevy 4X4 Olympia's fastest growing truck parts supplier. Olympia's home for Wayward Chevys |
11-21-2007, 01:00 PM | #3 |
67-71 bb mounts had an upper that attached to the motor with a smaller lower piece ,with a frame towers kinda like the small block but had a bigger hole and different sitting . in 72 the big blocks went to the later clam shell motor mounts ,a completly different flater frame tower .
'70 k-10 longbox- mid 70's drivetrain 350/350 487x heads 10.1:1 flowmasters ,35's 3.73's auburn posi ,rear shackle flip. '72 short stepside U.S. forestry truck, '73 455 buick,400 turbo,dropped 2"-4 1/4" ,3.07 posi,:'89 silverado 1500 ,OK truck ,5.7 holley tbi ,trick 700r4 3.07 auburn posi ,and my '66 skylark ,'73 centurion and my '84 monte carlo imca stock car |
11-21-2007, 02:07 PM | #4 |
member #16
Heres a how to on using 73-87 mounts in a 67-72 truck. These mounts are cheap and plentiful.
http://67-72chevytrucks.com/vboard/s...d.php?t=128765
john http://67-72chevytrucks.com/vboard/showgroups.php board vendors http://www.flickr.com/photos/1745471...7602865984234/ Last edited by john; 11-21-2007 at 02:07 PM. |
11-21-2007, 02:13 PM | #5 |
PROJECT 7DEUCE
I used the early stell frame mounts with 350 rubbers I believe,its been so long since I looked at it. I do know the I got the idea off of herefrom board member tx firefighter I believe..
GO BIG GREEN GO DUCKS MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. |
11-21-2007, 07:29 PM | #6 |
Always on the hunt...
Here are pics of the two types of BBC towers that were used in all 68-72 factory 396/402 2wd trucks, the 68-71 type are in the top pic and the 72's are in the bottom pic. Cb
11-21-2007, 07:38 PM | #7 |
CSK shows the same motor mount for SBC and BBC. Imagine my surprise when I attempted to replace my 402 mounts. It grew to a horror show when I priced mounts at the GM dealer.
72 C2500 LWB 402 Sierra Grande 05 Odyssey 08 Tundra |
11-21-2007, 08:55 PM | #8 |
PROJECT 7DEUCE
i USED THE 68-71 WITH THE 350 CUSHIONS..
11-21-2007, 09:08 PM | #9 |
I bought some motor mounts from performance online and they worked perfect. They had no issues with clearance with headers or anything. Also they looked better than stock, they are tubular in design and the polyurethane motor mounts were also available for an additional $50. I want to say that i paid around 150 for the complete set. Goto performanceonline.com.
11-21-2007, 10:12 PM | #10 |
They work well, a couple of guys around here have used them.
11-21-2007, 11:07 PM | #11 |
Thanks Guys for all the help. Do you just use 350 motor mounts with the 68-71 mounts? If I was to use the 72 do I have to modify my frame?
DREW67 |
11-27-2007, 04:46 PM | #12 | |
"A man and his truck, what a beautiful thing" 65 Short Fleetside BBC 65 Long Fleetside 283 3 on the tree for now. my build thread http://www.67-72chevytrucks.com/vboa...d.php?t=259536 |
11-27-2007, 05:52 PM | #13 |
I have removed a 396 from a 69 GMC which has motor mounts that look like the first picture shown, can I use the motor mounts in my 71 Chevy?
Richard Dobson |
11-27-2007, 06:30 PM | #14 |
Watch out for your cornhole !
Absolutely. They are the correct mounts for a 71 model too and will bolt in without modification.
11-27-2007, 07:23 PM | #15 |
Today I test fitted the 72 on my 67 and they do not line up right with the top frame rails and holes and then there is a 1/4" gap between bracket and frame rail.
DREW67 |
11-27-2007, 08:25 PM | #16 | |
They look extremely similar. Easiest way to differentiate between the two types is to count the number of ribs on them. 72 has one rib. 73+ has 2 ribs.
11-27-2007, 08:39 PM | #17 |
Here are a few pictures of what I'm talking about. I mounted one the bolts to the cross memeber it is the only one that lined up. This occurs on both sides.
DREW67 |
11-27-2007, 08:45 PM | #18 |
They're definitely 72 big block mounts.
It does seem like I read in the past that 67's sometimes needed some slight frame mod to do this since they were never engineered to be factory big blocks. I'm out of my element here though, as I've had 3 big block trucks, a 69, a 70 and now a 72, never a 67 though.
11-27-2007, 11:05 PM | #19 |
67-72 parts collector,…
Doesn't the top rail need to be trimmed? As in narrowed so the top bolt holes will line up. Also,...if running headers,... you might want to test fit them so you can grind a little frame clearance.
Keith Convert to disc brakes. http://67-72chevytrucks.com/vboard/s...d.php?t=444823 Last edited by lolife99; 11-27-2007 at 11:09 PM. |
11-27-2007, 11:10 PM | #20 |
its all about the +6 inches
Tx... I'm pretty sure you are right on that.
