Old 11-21-2007, 02:10 PM   #1
jfalesi
Junior Member
Rear end calculator (your truck's, not yours)
For reference, a 3.73 rear end is assumed. In 3rd gear (or direct drive), at 50mph your engine rpms will be 2000. To calculate your actual rear end ratio, check your rpms at 50 mph (only works in 3rd/direct drive gear). Divide your rpms by 2000 and multiply by 3.73. For example, if your rpms at 50mph are ~ 1850, you have a 3.42 rear end (1850/2000 = 0.92, 0.92 * 3.73 = 3.42).
jfalesi is offline   Reply With Quote
Old 11-21-2007, 04:15 PM   #2
Ace in the hole
Re: Rear end calculator (your truck's, not yours)
or just use this- http://www.angelfire.com/fl/procrastination/rear.html
1970 K20, 350--- SOLD
05 silverado extended cab short box- duramax
Jeep wrangler unlimited
Ace in the hole is offline   Reply With Quote
Old 11-21-2007, 04:19 PM   #3
LMN8UR
LMN8UR's Avatar
But of course that varies with tire size.
If anyone is interested I wrote a little excel file that lets you change ratios - tire sizes - and transmission and it shows you RPM & Speed.
PM me with you email and I'll send it to ya.
72 Chevy C-10 Custom LWB
383 Stroker - Edlebrock Air Gap intake and 670 CFM Holley Street Avenger carb.
Hooker Comp Headers w/ X-Pipe and 2.25 duals
TKO-500 & 3.08:1 rear
I Love HEMI's, they're soft & chewy!
LMN8UR is offline   Reply With Quote
Old 11-21-2007, 05:07 PM   #4
jfalesi
Junior Member
Oh yeah, I forgot. I assumed a 31" tire size. I generated an excel spreadsheet also, but I lost it. I'll be pm'ing you...
