Old 11-21-2007, 05:01 PM   #1
Guy58
Smile Cab Question
Can anyone tell me how I could tell what carburator my truck has. I would like to rebuild it and want to but a kit. I have a 1967 250ci Inline 6 with a 3 speed manual trany. I am pretty sure it is a one barral but do not know if it is a Rodchestor or Carter. Thanks and Happy Thanksgiven to everyone.
Guy58 is offline   Reply With Quote
Old 11-21-2007, 05:47 PM   #2
Blue71LWB
Blue71LWB's Avatar
Re: Cab Question
The Roch should say Mono-jet on the front or Drv-side of the carb.
Working on my first 1,000 post.
I'm sure I'll get there before this project is over .
Blue71LWB is offline   Reply With Quote
Old 11-21-2007, 08:07 PM   #3
68gmsee
Active Member
68gmsee's Avatar
Re: Cab Question
More than likely it's a rochester but someone may have changed it. If you post a pic someone should be able to tell you what it is...
68gmsee is offline   Reply With Quote
Old 11-24-2007, 10:15 AM   #4
Guy58
Smile Re: Cab Question
Thanks guys, I looked around the back of the cab and Rochestor MC is stamped on it.
Old 11-24-2007, 10:21 AM   #5
Wrenchbender Ret
Re: Cab Question
It,s most likely a roch. model B. The monojet didn,t come out untill 68. If it is it will have 4 screws holding the air horn on. There should be a brass tag under 1 screw that identifies it but they are usually gone by now.
Wrenchbender Ret is offline   Reply With Quote
