Hatch latch ideas?
Anybody got an idea for an alternative way to latch your tops rear hatch down (pics too, if possible)? Mine never worked anyway & was missing the pieces that bolt inside on the top. So when I was repairing all the busted fiberglass, I cut the handle off because the bolts wouldn't budge & everything else was rusted together. Anyway, what can I do besides a bungi cord or duct tape
'72 C to K20 "Cannibalizer" http://67-72chevytrucks.com/vboard/s...32#post8653432 '85 K30 "Big Nassy" '06 3500 Duramax ...tow truck '06 Silverado SS...DD '06 C1500 WT...DD '07 Classic C1500 WT...DD Built & sold cause can't keep 'em all: '72 Blazer "The Bucket" http://67-72chevytrucks.com/vboard/s...d.php?t=433190 '55 Chevy straight axle gasser https://www.trifive.com/forums/showthread.php?t=173938 '69 Pro Street Chevelle http://www.chevelles.com/forums/showthread.php?t=332541 '86 M1031 CUCV http://67-72chevytrucks.com/vboard/s...d.php?t=553619 |
Re: Hatch latch ideas?
I wanna see also
Just brainstorming late tonight about this idea. I know it isn't anything close to being original, but what about this locking latch for the middle
![]() And some hardware on the sides somewhat like these to keep the sides in place? ![]() http://www.nauticexpo.com/prod/south...514-55394.html any other ideas? Not sure how the side hardware disengages. I was looking for the kinds that you push to lock and then push again to unlock, but this one seems to have a sliding lever used to unlock the latches. Last edited by tdkosta; 11-22-2007 at 01:15 AM. |
Sofa King. We, Todd, Ed.
I bought a couple of jeep style rubber hood latches with the intention of going low-tech and putting one each sideways on the lower corners but thought better of it after mocking it up.....
The guy I bought my jimmy from talked about a guy who repaired his with garage door latch parts. Said it worked better than the original.
This is what I ended up using. It's not the cleanest option, but works great and only $5 each from Lowes. I wouldn't dare use this on a show truck, however it works great for this gravel roads/mud bucket!
Global warming is a myth
I guess that will work OK. At least until the drip edge breaks off. I think you should go into a topper store or some place that sells truck camper tops. Open the hatch on one of those that has a single handle in the middle & you'll be kicking yourself for drilling holes into the exterior of you hatch. All you'd need is a plate, (to replace the hole in the end where the factory latch is at), with a hole in if to locate the rod.
Sounds harder than it is. Later, Buddy
Henderson, NV 1972 K5 - Lifelong project - Needs Time, Place, Help & Parts!! 1990 K5 with 37's 2003 Discovery SE7 - Wife's |
