Gotta Startem Early
Emergency Brake Handle
Can the e-brake handle under the dash be converted to a pedal brake or a hand brake in the floor? If so what do you use to convert?
67 SWB In Progress, one piece at a time, maybe 3 years I will be finished |
This has been covered before. just do a search on e-brake and check those threads.
If you want to use a 69-72 foot operated brake pedal you will have to make some mods to the firewall cause the fuse box is in a different location. Someone stated that they had used a later ( 80's) cable version foot pedal without too many mods. You can probably find that in the old threads. If you can: Look at the differences between the hand and foot operated cabs that will tell you alot. In the long run it is easier to keep the earlier style version.
John Hutchison Grapevine,Texas 68 1/2 t swb 68 Mustang 69 Jaguar 71 1/2 t swb 88 Supra CompTs6m 93 Escort GT 2005 Corolla XRS |
