Old 11-21-2007, 10:50 PM   #1
chev74
Addicted to Chevy
chev74's Avatar
Degreasing the engine bay
What have you guys used that seems to work the best? I need to clean of the top of the intake, valve covers, block, etc. they have that nice thick layer of grime that seems like its- i dunno 30 some odd years old!!
chev74 is offline   Reply With Quote
Old 11-22-2007, 12:09 AM   #2
67CHIP72
STOLEN
67CHIP72's Avatar
Re: Degreasing the engine bay
You can try Gunk and a preasure washer, but I don't know if it will harm the old paint.
In Search Of
67CHIP72 is offline   Reply With Quote
Old 11-22-2007, 12:42 AM   #3
dave2953
Dave's not here, man
dave2953's Avatar
I use some stuff called B-52. I get it at the local parts house. You have to dilute it a bit when spraying on painted surfaces because it will eat through paint at full strength.
- 2014 VW Jetta
- 2015 VW Jetta
- 1966 Ford F-250
dave2953 is offline   Reply With Quote
Old 11-22-2007, 01:54 AM   #4
71blksuper4x4
SWB 4x4 Collector
71blksuper4x4's Avatar
I have tried the trick of using gasoline, works wonders. Did it on a transfer case a few years back. Gas will eat threw the grease and grim. Hope this helps, but anymore, it maybe cheaper to buy cans of degreaser.
TREVOR
1970 CST swb 4x4 (speedwarning,cruise,tilt,tach,8track, original red shoulder belts,tow hooks)
1972 Jimmy (soon to be Hickey cloned)
1971 Cheyenne Super 4x4 swb (tilt,tach,buckets, original blue shoulder belts,am/fm,cruise,tow hooks, dealer 8 track)
1972 Cheyenne Super K20 4x4 Custom Camper (tilt, tach, am/fm, tow hooks, bed toolbox, aux gas tank
1972 Cheyenne Super Crew Cab K30 4x4 Duramax, Allison, np205, buckets, tow hooks (CURRENT PROJECT)
http://67-72chevytrucks.com/vboard/s...d.php?t=624819
1989 V3500 Crew Cab (454tbi, NV4500, np205)
1970 Chevelle SS (LS5 454,th400,8track,buckets,tach)
:2004 Jeep Wrangler Rubicon (daily driver)
WTB: 1968-70 Cruise Control Lever
71blksuper4x4 is offline   Reply With Quote
Old 11-22-2007, 02:59 AM   #5
jeffnohio
jeffnohio's Avatar
super clean and a wire brush
Jeff
1967 GMC 3/4ton LWB, Orginal Straight 6, 4 on the floor Project truck
jeffnohio is offline   Reply With Quote
Old 11-22-2007, 03:43 AM   #6
EAST SIDE LOW LIFE
EAST SIDE LOW LIFE's Avatar
Gunk has always worked good for my projects. I just use a garden hose to wash it off. You do not want to over do it with the water pressure. I've always detailed an engine afterwards so I've never been too concerned about condition of paint or the paint for that matter. Gunk comes in spray or foam I've always used the spray.
esll.
Tomorrow is for doing today's stuff.
This truck has just the right amount of energy for me!
Author: Warren Lake .... (member)
EAST SIDE LOW LIFE is offline   Reply With Quote
Old 11-22-2007, 05:11 AM   #7
retodd7711
chrome makes it go FASTER!
retodd7711's Avatar
Dollar store oven cleaner and a trip to the car wash. CHeaper than brand name degreasers and works great. Car washes have a grease seperator so that junk doesn't get in my water.Don't spray on motor and then drive to car wash, stinky!
She can't cook
and she won't clean.
But she looks good in a skirt
and she brings me beer.
She can stay for now.
EDIT:: But she left me anyway,
So forget her.
1962 GMC Stepside V6 4 speed
My rolling resto thread
http://67-72chevytrucks.com/vboard/s...d.php?t=324226
My old farm truck
http://67-72chevytrucks.com/vboard/s...=1#post3465005
retodd7711 is offline   Reply With Quote
Old 11-22-2007, 06:09 AM   #8
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
steam cleaner
Old 11-22-2007, 11:17 AM   #9
chev74
Addicted to Chevy
chev74's Avatar
i was thinking about the dollar store degreaser... gas is too expensive.
Old 11-22-2007, 11:25 AM   #10
jimmydiesel
jimmydiesel's Avatar
Soak with Simple Green and let it sit for a while then rinse it off. Depending on how baked on the grease is you may need to take a stiff bristled brush to it before you rinse it off. Works better and a lot cheaper than degreaser and no fumes.
jimmydiesel is offline   Reply With Quote
Old 11-22-2007, 12:00 PM   #11
cdowns
cdowns's Avatar
spic-n-span granules with water and a stiff parts cleaning brush then rince with a hose or powerwasher has always worked pretty good for me
Old 11-22-2007, 12:16 PM   #12
CJJ67
What has always worked really well for me, and it's cheap, is dish washing liquid, a scrub brush and "hot water". Hook your water hose to the hot water side for the washing machine. Wear a pair of rubber gloves (hot hose you know) and go at it. Works really well.
CJJ67 is offline   Reply With Quote
Old 11-23-2007, 04:34 PM   #13
dave3156
Another vote for Simple Green. Use it full strength, spray it on and let it sit a few minutes then spray off with hose. You may have to do it a number of times and like already said if the stuff is really thick, use either a wire brush, or if you don't want to scratch the paint, use a stiff bristle brush. I did mine that way and it turned out nice. When it ran on the driveway underneath it also removed the oil spots!
dave3156 is offline   Reply With Quote
Old 11-23-2007, 05:08 PM   #14
60ratrod
yes, i do
60ratrod's Avatar
i used carb cleaner when i cleaned up the motor that i put back into my 60. cleaned it up really good and ate through all the grease grit and grime. but it took me like 3-4 cans and a bunch of rags to get it clean though.
ERROR 404....... SNAPPY COMEBACK NOT FOUND
_______________________________________________________________________________________________
-60 Chevy C10, dead 350/good th350 combo, sitting on a 76 c10 blazer frame, built from 11 different vehicles "the abomination"
-07 gmt900 silverado 1500 lt xcab z71, granite blue
-81 suzuki gs650g "shelah"- current project
-81 kz1000m1 csr "sarge" -next project (just beautification)
-07 kawasaki vulcan classic vn900
60ratrod is offline   Reply With Quote
Old 11-23-2007, 11:14 PM   #15
JAKES 68GMC
Aluminum slot wheels rule...
Super Clean will put Simple Green to shame, at least in my experience.
JAKES 68GMC is offline   Reply With Quote
Old 11-24-2007, 12:03 PM   #16
odog
odog's Avatar
I use deisel smoke remover from our steam store combined with pressure washer on our Rock drills. It cleaners all the baked on grime, oil etc. I just put it in a spray bottle spray it on let it sit for 15 min. then rinse off. Should work on an engine, same basic grime, also cleans my work cloths.
1969 4x4
Nothing beats a good rock drill and some dynamite
odog is offline   Reply With Quote
Old 11-24-2007, 03:03 PM   #17
68caliRat
Need a bigger hammer..
Hell I just use straight Diesel. it melts even the toughest baked on grease with a little help from tooth brush or other scrub brush.
1968 GMC 3/4 LWB fleetside Custom Camper
2018 Silverado High Country 2500HD Duramax 4X4
68caliRat is offline   Reply With Quote
Old 11-24-2007, 03:32 PM   #18
DURRTY
USMC
DURRTY's Avatar
Gasoline is kinda FLAMABLE too!!! wow diesel will work and be safer if your going that way. It stinks and will stink for a while after your done and its greasy so if you want to paint on those areas its a pain to prep.
It kinda gets down to how much actual labor you want to put in.
Semper Fi
DURRTY is offline   Reply With Quote
