relocating ignition?
i would like to relocate my ignition switch so that when the keys are in it they dont hang down and scratch my paint.
anyone done this, have pictres or an idea for where i could relocate it too? i do have a full center console from the dash to the back of the cab between my buket seats. (see pics in my build thread) i was thinken there or on the botton edge of the dash
68 swb fleet bagged on 20's 327 with 4 speed http://67-72chevytrucks.com/vboard/s...d.php?t=223308 2014 Chevy 2500hd duramax CCLB |
Its Topless Season!!!!
Re: relocating ignition?
Son of a gun
Take the ignition key off of the ring. Then the rest of the keys won't be hanging down. That seems a whole lot easier that relocating.
Bill BEATERS ARE NEATER |
Put a piece of tape on the dash under the key
72 C2500 LWB 402 Sierra Grande 05 Odyssey 08 Tundra |
PROJECT 7DEUCE
![]() Join Date: Dec 2002
Build urself the little piece of metal and then glue it under the key set..
GO BIG GREEN ![]() MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. |
How about this:
![]() Brothers Link: http://www.brotherstrucks.com/prodin...number=BR10035 Hope this Helps! Shawn
1972 C20 Suburban- Big Blue Betty '56 Chevy Bel Air Sedan- Frame up Restoration -What would you attempt to achieve if you knew you could not fail?- -I Refuse To Tiptoe Through Life, Only To Arrive Safely At Death's Door- R.I.P. EAST SIDE LOW LIFE |
Active Member
![]() Join Date: Jul 2007
What I did on mine...
Made a duplicate. Placed it in my key chain. Used the other single key for the ignition switch. Keep my other keys in my pocket. The reason for the duplicate is in case I forget and leave the key in the ignition. Which I've done more often than I'd care to admit. ![]() |
Active Member
I guess I should have mentioned. I have 3 trucks and a suv. By "mine" I meant all of them. I use a single key on all the vehicles and keep spares in my key chain. I have up to 10+ keys on my key chain/ring and it will also wear down your ignition switch with all the weight...
