Old 11-22-2007, 01:34 PM   #1
mateo1279
mateo1279's Avatar
exhaust manifold lever?
So...
I was changing out spark plugs and ran across something I hadn't noticed before: A square piece of metal that leads near the (stock) exhaust manifold. I pushed down on it and it moved like a lever... anyone know what this might be.... if it is a mystery I can put up a pic...
Matt
1962 Chevy Fleetside
283/TH350
mateo1279 is offline   Reply With Quote
Old 11-22-2007, 05:54 PM   #2
Fred T
Cantankerous Geezer
Fred T's Avatar
Re: exhaust manifold lever?
Sounds like the heat riser. Is it in the collector? If it is the riser, there should be a coiled spring that closes the valve when the exhaust is cool.
On a 283 when the engine is cool, the exhaust is diverted from one side through a passage in the intake that warms the area under the carb, helping atomize the fuel.
Fred
There is no such thing as too much cam...just not enough engine.
Fred T is offline   Reply With Quote
Old 11-22-2007, 08:59 PM   #3
C10-Driver
Chevy Truck Addict
C10-Driver's Avatar
Vehicles equipped with a riser usually used a snorkel style air cleaner that was hooked up to the manifold with a flex tube. Hot air from the manifold would be drawn into the carb feeding it with warm air until the engine heated up.
If it is not being used anymore, you should wire it open.
1970 Chev C/10 SWB, 355 SBC, 700R4, 3.73 Posi, Air Ride (Click to view Build Thread) (SOLD)
1978 Chevy C/10 SWB
1970 Pontiac Lemans
C10-Driver is offline   Reply With Quote
Old 11-23-2007, 12:17 AM   #4
mateo1279
mateo1279's Avatar
That makes scene! Thanks for the tips!
-Matt
283/TH350
Old 11-23-2007, 04:04 AM   #5
Ham-er
Yep many of these engines had both. The exahst diverter on one side and the intake damper on the other side.
Ham-er is offline   Reply With Quote
Old 11-25-2007, 08:36 PM   #6
mateo1279
mateo1279's Avatar
so then are there any benefits to keeping these systems in place? performance or drivability wise?
283/TH350
Old 11-26-2007, 10:16 AM   #7
Ham-er
Same old carb and intake? then Yes for cold drivability. Performance,nah.
Both systems just warm things up quicker basically, helps the fuel burn better till engine warms up, so helps when its cold.
