Burnouts are therapeutic
Is There A Difference In Power Steering Gearbox 71 Gmc Vs. 68 Chevy?
Found Gearbox,pump,hoses,automatic Column Out Of 71 Gmc For $100 ,wondering If There Is A Difference Between It And One For A 68 Chevy Or If It Will Work ,and If It Is Diff. What Changes Are Necessary,(he Also Has Good Cab I'm Thinking Theres No Diff. In Cabs Correct Me If I'm Wrong.) Thanks For Any Input
1969 CHEVELLE SS 1972 C10 ALMOST DAILY DRIVER 1968 C10 RUSTBUCKET (MISSION IMPOSSIBLE) 1972 PONTIAC LEMANS CONVERTIBLE (WIFE'S CAR) "My wife and I were happy for twenty years. Then we met." - Rodney Dangerfield "The difference between genius and stupidity is that genius has its limits." - Einstein |
![]() Join Date: Jun 2002
Re: Is There A Difference In Power Steering Gearbox 71 Gmc Vs. 68 Chevy?
my 68 had the old style power steering that uses an assist cylinder mounted on the drag link. I had to "heat & beat" a bump in the frame rail to make clearance for the later model power steering steering box, & replace the drag link. Other than that, its a bolt on.
The kid Build threads: 51 Jimmy http://67-72chevytrucks.com/vboard/s...d.php?t=154951 http://67-72chevytrucks.com/vboard/s...d.php?t=219902 http://www.classictrucks.com/feature...uck/index.html 68 C10 http://67-72chevytrucks.com/vboard/s...ad.php?t=50348 |
Some of the 68's had the old style ps setup and many had the all in one box power steering unit like the one you would like to put in.
Some would say you can shim the box out with washers. best bet is to get the plate kit to mount it if your wanting to do the swap and the frame doesn't have the indent in it already. ![]()
Scott 66 chevy short step 327 4speed 67 chevy Short Fleet tpi 350 700r4 72 chevy K10 swb 01 GMC Sierra 01 Pontiac Bonneville |
shade67 so you can buy shim kit to make it work?kid do you have to change drag link if i currently have manual steering? is indention in chasis diff. between 68 vs.71?
Red,
no you don't have to change the drag link- the pitman arm should bolt into the draglink and wedge into it like the original one did. The shim kit is available from Classic Parts of America for Appx. $59.95. p/n 76-979 looks like it comes with the bolts. You will only need if the frame doesn't have the indent in it. Also you should note the part is listed as for the 60-66 but works equally as well for the 67-early 68's! ![]()
shade67 said it right, if your current drag link is a manual, you wont have to change it. I thought about using the shim kit for the box, but I wanted to keep the alignment between the colum & box as close to straight as possible so I chose to create the indent in the frame (& saved the $60.00). Yours might already have the indent.
thanks for the info guys,seems no matter what the question someone here has the answer when it comes to these trucks
