Old 11-22-2007, 07:52 PM   #1
ibad57
ibad57's Avatar
Heater hose Question
What are the two sizes hose required on 72 c 10 v8 for the heater core I need to buy two pipe outlets for the engine and water pump?????
My Project Old Glory trike visit here http://www.facebook.com/home.php?#!/...48577705162172
ibad57 is offline   Reply With Quote
Old 11-22-2007, 08:01 PM   #2
tcb-1
Nothing to see here.....
tcb-1's Avatar
Re: Heater hose Question
you'll need 5/8" and 3/4". 3.5' of each depending on how you route them.
tcb-1 is offline   Reply With Quote
Old 11-22-2007, 08:05 PM   #3
WorkinLonghorn
WorkinLonghorn's Avatar
5/8" and 3/4"
'69 GMC C2500 Custom Camper, 8 1/2' bed, New GM 350, NP 435 Close Ratio 4spd. Trans., 3.73 Dana-60 open.Camper and Trailer wiring, PS, PB, AC, tach , three gas tanks, stereo speakers, 2nd owner, Work-Truck supreme.
WorkinLonghorn is offline   Reply With Quote
Old 11-22-2007, 08:23 PM   #4
chipflyer
chipflyer's Avatar
5/8 from the intake to the lower heater core fitting, return to the water pump or radiator from the upper heater core fitting with the 3/4 hose.
Jeff
I'm not a pessimist, I'm just optimistic that bad things are going to happen.
1971 Cheyenne Super K10 - tilt, cruise, air, am/fm, tow hooks, factory buckets!
1986 Jeep J10 pickup, - 5.3L Vortec with 4L60e and NP241.
chipflyer is offline   Reply With Quote
Old 11-22-2007, 09:22 PM   #5
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
And the threads will be 1/2 NPT
Old 12-30-2007, 07:54 PM   #6
myraley
myraley's Avatar
Smile Re: Heater hose Question
Sorry to just in, but I had a related question. Would that same routing be true on a 454 big block? Or does that just apply to small blocks? I am trying to route the hoses on mine because when I bought my truck, the heater core and hoses were all missing. I was thinking of just having both hoses go to the water pump. Would that be ok? Thanks!
myraley is offline   Reply With Quote
