Old 11-22-2007, 08:09 PM   #1
BP68
BP68's Avatar
GMC Longbed shorten w/leafs??
Hey all,
I have a 70 GMC longbed truck with a Chevy front clip on it. I will prob sell it, but was wondering if anyone has shortened a longbed frame that has rear leafs rather than springs/trailing arms? Just wondered how much diff the process would be.
68 C10 Shortbed Fleetside
06 Chevy Ext Cab Fleetside
03 Grand Prix GTP
My build thread http://67-72chevytrucks.com/vboard/s...d.php?t=269999
BP68 is offline   Reply With Quote
Old 11-22-2007, 09:23 PM   #2
duceducenine
duceducenine's Avatar
Re: GMC Longbed shorten w/leafs??
early classic shortens the frame under the cab with that you only change the rear cab mount...which i did to my 67 but i have coils but doesnt change to process earlyclassic.com tech articles
duceducenine is offline   Reply With Quote
Old 11-22-2007, 10:09 PM   #3
1969k10stepside
The frames are the same,just the spring hangers and springs are there and not trailing arms..The chunk taken out to make a shortbed isn't between the leafs so no issues there.Basically the same as shortening one w/ trailing arms,just don't mess around with relocating the crossmember for the trailing arms forward.
1969k10stepside is offline   Reply With Quote
Old 11-24-2007, 03:17 PM   #4
duane67c-10
duane67c-10's Avatar
I have a gmc frame too that i have shortened, the only problem is the bumper bracket bolts where the leafspring is but im going to run a rollpan.
duane67c-10 is offline   Reply With Quote
Old 11-24-2007, 03:29 PM   #5
Rokcrln
Rokcrln's Avatar
Look up "lfd's low buck truck build" and you will find everything you need in a step by step thread.
Kevin
LFD Inc.
Rokcrln is offline   Reply With Quote
Old 11-25-2007, 09:56 AM   #6
N2TRUX
Happy to be here
N2TRUX's Avatar
Go to the FAQ forum and there is an awesome "how to" there....
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
