Old 11-22-2007, 08:17 PM   #1
drbyrdman
drbyrdman's Avatar
Throttle rod
Were can I get a new throttle rod for my 67?? I have a new 650 double pumper and the rod I have is bent up and looks like crap.
drbyrdman is offline   Reply With Quote
Old 11-22-2007, 10:20 PM   #2
drbyrdman
drbyrdman's Avatar
Re: Throttle rod
Does anyone make one???
Old 11-23-2007, 12:48 AM   #3
krue
Designated A-hole!
krue's Avatar
Re: Throttle rod
I think your only option is to post a WTB on the parts board for a used one, I don't think these are being reproduced.
Being stupid ain't illegal.
www.daveramsey.com
93 S-10 "Poppaw's Truck"
Old 11-23-2007, 11:09 AM   #4
drbyrdman
drbyrdman's Avatar
Re: Throttle rod
I found a couple. Iam going to make this one.
Old 11-23-2007, 11:15 AM   #5
Shock_Me
Shock_Me's Avatar
Re: Throttle rod
Hey drbyrdman, make one for me too!!
Shock_Me is offline   Reply With Quote
Old 11-23-2007, 02:27 PM   #6
corn
Re: Throttle rod
I made mine. The stock one didnt fit my crooked carb...
corn is offline   Reply With Quote
Old 11-23-2007, 05:36 PM   #7
HD2000
HD2000's Avatar
Re: Throttle rod
Hey drbyrdman,
I was planning to do this a couple of years ago but had no luck finding any of the end links (they called Heim joints?).
Do you know where they can be found?
(for now I have the bent coat hanger version)
HD2000 is offline   Reply With Quote
Old 11-23-2007, 09:50 PM   #8
BCOWANWHEELS
Re: Throttle rod
speedway motors sells heim joints and you dont need chrome moly one also....
bob
I BELIEVE IN JOHN 3:16
BCOWANWHEELS is offline   Reply With Quote
Old 11-24-2007, 01:58 AM   #9
Rdrdave
Broke and still trying
Rdrdave's Avatar
Re: Throttle rod
i went to the local OSH and bought female heims on both ends, threaded rod, jam nuts and the aluminum fuel line tubing to cover the threaded rod. DONE!
Rdrdave is offline   Reply With Quote
Old 11-24-2007, 03:09 AM   #10
60ratrod
yes, i do
60ratrod's Avatar
Re: Throttle rod
that looks nice. might have to make one for my 60 so i can use my gas pedal again. had to take out the pedal when i added the carb spacer so all i got is my rod for right now. there might be some aircraft parts that i can aquire for that........
ERROR 404....... SNAPPY COMEBACK NOT FOUND
_______________________________________________________________________________________________
-60 Chevy C10, dead 350/good th350 combo, sitting on a 76 c10 blazer frame, built from 11 different vehicles "the abomination"
-07 gmt900 silverado 1500 lt xcab z71, granite blue
-81 suzuki gs650g "shelah"- current project
-81 kz1000m1 csr "sarge" -next project (just beautification)
-07 kawasaki vulcan classic vn900
60ratrod is offline   Reply With Quote
Old 11-24-2007, 07:10 PM   #11
EAST SIDE LOW LIFE
EAST SIDE LOW LIFE's Avatar
Re: Throttle rod
This is a good idea. I like using the fuel line to cover the threaded rod, nice finishing touch. The biggest problem with my throttle rod is that I had to weld an extention onto it and I don't like the fact that you can see the join .... with the fuel line the problem is resolved and looks good as well.
esll.
Tomorrow is for doing today's stuff.
This truck has just the right amount of energy for me!
Author: Warren Lake .... (member)
EAST SIDE LOW LIFE is offline   Reply With Quote
Old 11-25-2007, 07:24 AM   #12
68Stepbed
68Stepbed's Avatar
Re: Throttle rod
I made mine with heim joints and threaded rod also. I got my stuff from Lokar products. It would've been a little pricey, but I got a deal on some discontinued heim joints.
www.lokar.com
Matt
68 C10 stepside, LS1/700R4, TCI Engineering suspension system
68Stepbed is offline   Reply With Quote
Old 11-25-2007, 08:57 AM   #13
whitelightenin69
whitelightenin69's Avatar
Re: Throttle rod
Made mine a couple of months ago, found all the parts at napa, heim joints are also known as spherical rod ends.
whitelightenin69 is offline   Reply With Quote
Old 11-25-2007, 06:23 PM   #14
68GMCCustom
Truck and auto performance nut
68GMCCustom's Avatar
Re: Throttle rod
Mine doesn't have enough travel to completely open the Rochester 4V thats on mine. Any tricks to this? Or do I need to swithc to a cable setup?
If so, I'd sell you my throttle rod setup.
Kurt -
'68 GMC short step - NIB '09 LY6 6.0L crate motor w/mods, NIB '12 crate 4L85e w/billet 3k stall Circle D, 3.73 posi 12 bolt, DynaTech f-swap headers, 3/4 drop, handling mods, etc. - my toy
'72 Chevy LWB C-10 Highlander - 350/350 ps/pb/tilt/ac - not original but close
'06 Chevy TrailBlazerSS - LS2/4L70e - little black hot rod SUV - my DD
'18 Kia Sorento - wife's econo-driver
'95 Chevy S10 - reg cab shortbed, LS, 4.3, auto...
my '68's powertrain and chassis build -links broken
A surprise phase - carb to efi -links broken
68GMCCustom is offline   Reply With Quote
Old 12-16-2007, 07:56 PM   #15
drbyrdman
drbyrdman's Avatar
Re: Throttle rod
I went to the hardware store and bought a piece of 1/4" fine threaded rod, a piece of brake line to cover it, and the parts store had the Heim joints. I could make some if anyone wants one. It works great!
Old 12-17-2007, 05:16 AM   #16
clay68c10
clay68c10's Avatar
Re: Throttle rod
Those spherical rod ends make the throttle so much more smooth than the original rod. Here's what I used:
http://www.bakerprecision.com/longacr53.htm
It was so cheap and felt so much smoother that I'd do this to any mechanical throttle linkage.
68GMCCustom; you probably need to just shorten up your linkage. That should get you full throttle. I had to change the length on mine when I went from carb to TBI so I would still get wide-open.
ClusterTruck: 68 C10 Bought in 89, wrecked in 03. Slow low $ rebuild started '17. 6.0 & TKO
http://67-72chevytrucks.com/vboard/s...d.php?t=788602
93 K1500 Short Step, 350, NV4500, EBL flash ECU. Vortec heads & roller cam someday...
05 Jeep Wrangler Unlimited. 3” lift & 6-speed
02 E320 the insurance total “free car”
13 Tahoe LTZ
clay68c10 is offline   Reply With Quote
